Installation & Licensing
Autodesk Building Design Suite Premium 2014: Error 2350
3 REPLIES 3
617 Views, 3 Replies
Hi Autodesk Community, Long time user and lurker, first time poster (pity it wasn't under happier circumstances) I'm trying to install Autodesk BDS Premium 2014 LOCALLY and I'm getting the errors seen below: [url=http://postimg.org/image/jtv4ucqaz/][img]http://s1.postimg.org/jtv4ucqaz/WTFFF.jpg[/img][/url] [url=http://postimg.org/image/a49l2lmur/][img]http://s29.postimg.org/a49l2lmur/WTFFF.jpg[/img][/url] So it's telling me it's having issues writing iqlib.dll, and then throws up an error 2350 I've done some searching, and other threads in this forum with the same error code were dealing with Deployments. Some people made the recommendation of shortening the UNC path. Considering this is a local drive, I didn't expect this to be an issue, but I shortened the address anyway, to C:\Autodesk to no avail I'm running the installer as an Administrator, and I have also disabled UAC Can someone tell me what I'm doing wrong?
3 REPLIES 3
TravisNave
I unfortunately cannot see your images.  Can you just post them to this thread, plus any installation log file that you have?
Autodesk Forums:
EDIT: failed to upload the pics in this post, unsure how to delete it 😞
Ok, my firefox is causing a bit of trouble with the forum so I'll try this again
Administrator Productivity
