Hi, I have a MacBook Pro on which I have Autodesk Maya 2011. I had no problems with it until recently when I installed VMWare fusion on my machine. Now I have problems with internet connectivity occasionally. In troubleshooting the issue I tried logging into my modem at 192.168.2.1 and the BackBuner page pops up! I had no idea what BackBurner even was at that point. So my question is, how do I get BackBurner from hijacking my modem's IP address?
Any ideas?
Solved by david.lau. Go to Solution.
Just manually delete Backburner on the Mac. There should be a folder in Applications > Autodesk and the following
/usr/discreet/backburner
/usr/discreet/lib32/backburner
"Just manually delete Backburner on the Mac. There should be a folder in Applications > Autodesk and the following
/usr/discreet/lib32/backburner "
Ok, there is definitely not a Backburner folder within Applications > Autodesk
I found the usr/discreet/backburner folder using command line. I removed it. But I still have the same problem.
This is what is in my Autodesk folder
Adlm MatchMover2011 maya2010
Composite 2011 SketchBookPro2010 maya2011
MatchMover2010 Toxik 2010
What am I missing? I don't see Backburner here?
Thanks for your help.
