Installation & Licensing
Autodesk BackBurner - Mac and VMWare Fusion - IP Conflict
3 REPLIES 3
tbivans
3270 Views, 3 Replies
Hi, I have a MacBook Pro on which I have Autodesk Maya 2011.  I had no problems with it until recently when I installed VMWare fusion on my machine.  Now I have problems with internet connectivity occasionally.  In troubleshooting the issue I tried logging into my modem at 192.168.2.1  and the BackBuner page pops up!  I had no idea what BackBurner even was at that point.  So my question is, how do I get BackBurner from hijacking my modem's IP address?
Any ideas?
3 REPLIES 3
david.lau
in reply to: tbivans
Just manually delete Backburner on the Mac.  There should be a folder in Applications > Autodesk and the following
/usr/discreet/backburner
/usr/discreet/lib32/backburner
David Lau
tbivans
"Just manually delete Backburner on the Mac.  There should be a folder in Applications > Autodesk and the following
/usr/discreet/lib32/backburner  "
Ok, there is definitely not a Backburner folder within Applications > Autodesk
I found the usr/discreet/backburner folder using command line.  I removed it.  But I still have the same problem.
This is what is in my Autodesk folder
Adlm            MatchMover2011        maya2010
Composite 2011        SketchBookPro2010    maya2011
MatchMover2010        Toxik 2010
What am I missing?  I don't see Backburner here?
Thanks for your help.
david.lau
You may also need to delete this file:
/Library/LaunchDaemons/com.autodesk.backburner*
David Lau
Administrator Productivity
