Installation & Licensing
New Member
0 Kudos
Post 1 of 1
Autodesk AutoCAD Architecture 2013 x64
163 Views, 0 Replies
03-14-2013 11:40 AM
2013/3/14:18:00:51 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:18:00:51 Илия ИЛИЯ-VAIO Launch 2013/3/14:18:01:00 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:18:00:53 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:18:00:53 Илия ИЛИЯ-VAIO Launch 2013/3/14:18:01:00 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:18:01:05 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:18:01:11 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:18:02:17 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:18:03:37 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:18:03:37 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:18:04:02 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:18:04:04 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AI849C.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:18:08:22 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:18:08:23 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:18:08:23 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:18:08:39 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:03:25 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:03:25 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:03:38 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:03:27 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:03:27 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:03:38 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:19:03:40 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:19:03:42 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:19:05:10 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:19:05:22 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:19:05:22 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:19:06:27 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:19:06:27 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AI7D69.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:19:11:01 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:19:11:01 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:19:11:03 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:19:11:33 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:27:37 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:27:37 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:27:48 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:27:38 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:27:38 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:27:43 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:19:27:51 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:19:27:54 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:19:28:14 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:19:29:39 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:19:29:39 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/3/14:19:29:48 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/3/14:19:29:48 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:19:29:53 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:19:29:53 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:19:30:12 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:19:30:13 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AIA61E.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:19:32:54 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:19:32:55 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:19:32:57 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:19:36:08 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:43:02 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:43:02 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:43:09 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:19:43:03 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:19:43:03 Илия ИЛИЯ-VAIO Launch 2013/3/14:19:43:06 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:19:43:12 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:19:43:13 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:19:43:34 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:19:45:21 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:19:45:21 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/3/14:19:45:23 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/3/14:19:45:23 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:19:45:29 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:19:45:29 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x86_2010.log 2013/3/14:19:45:51 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/3/14:19:45:51 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x64_2010.log 2013/3/14:19:45:58 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/3/14:19:45:58 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:19:46:30 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:19:46:32 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AIC2E1.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:19:50:04 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:19:50:04 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:19:50:04 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/3/14:19:50:04 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/14:19:50:06 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:19:56:34 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:20:07:50 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:20:07:50 Илия ИЛИЯ-VAIO Launch 2013/3/14:20:08:01 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:20:07:51 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:20:07:51 Илия ИЛИЯ-VAIO Launch 2013/3/14:20:08:01 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:20:08:05 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:20:08:07 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:20:09:39 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:20:11:28 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:20:11:28 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/3/14:20:11:34 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/3/14:20:11:34 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:20:11:39 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:20:11:39 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x86_2010.log 2013/3/14:20:11:46 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/3/14:20:11:46 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x64_2010.log 2013/3/14:20:11:52 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/3/14:20:11:52 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:20:12:58 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:20:12:59 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AI83A.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:20:17:21 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:20:17:21 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:20:17:21 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/3/14:20:17:21 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/14:20:17:22 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:20:20:15 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:20:35:14 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:20:35:14 Илия ИЛИЯ-VAIO Launch 2013/3/14:20:35:27 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:20:35:15 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:20:35:15 Илия ИЛИЯ-VAIO Launch 2013/3/14:20:35:26 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:20:35:27 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:20:35:29 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:20:36:49 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:20:37:01 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:20:37:01 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/3/14:20:37:06 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/3/14:20:37:06 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:20:37:14 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:20:37:14 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x86_2010.log 2013/3/14:20:37:21 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/3/14:20:37:21 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x64_2010.log 2013/3/14:20:37:27 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/3/14:20:37:27 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:20:38:32 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:20:38:32 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AIC725.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:20:43:19 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:20:43:19 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:20:43:19 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/3/14:20:43:19 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/14:20:43:20 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:20:46:43 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:21:34:42 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:21:34:42 Илия ИЛИЯ-VAIO Launch 2013/3/14:21:34:53 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:21:34:49 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:21:34:49 Илия ИЛИЯ-VAIO Launch 2013/3/14:21:34:54 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:21:34:56 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:21:35:00 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:21:36:16 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:21:37:31 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:21:37:31 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/3/14:21:37:34 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/3/14:21:37:34 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:21:37:39 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:21:37:39 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\36E3~1\AppData\Local\Temp\vcredist_x86_2010.log 2013/3/14:21:37:45 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/3/14:21:37:45 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:21:38:21 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:21:38:21 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AI9877.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:21:42:14 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:21:42:14 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:21:42:14 Илия ИЛИЯ-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/14:21:42:17 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:21:54:16 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:22:07:51 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:22:07:51 Илия ИЛИЯ-VAIO Launch 2013/3/14:22:10:14 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:22:10:14 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:22:10:26 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:22:10:46 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:22:10:53 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:22:10:53 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:22:11:21 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:22:11:22 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AIEEB2.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:22:14:01 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:22:14:02 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/3/14:22:14:03 Илия ИЛИЯ-VAIO PageOpen InstallCompleteDialog 2013/3/14:22:14:15 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:22:26:54 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:22:26:54 Илия ИЛИЯ-VAIO Launch 2013/3/14:22:31:54 Илия ИЛИЯ-VAIO === Setup ended === 2013/3/14:22:26:55 Илия ИЛИЯ-VAIO === Setup started on ИЛИЯ-VAIO by Илия === 2013/3/14:22:26:55 Илия ИЛИЯ-VAIO Launch 2013/3/14:22:31:54 Илия ИЛИЯ-VAIO PageOpen LaunchDialog 2013/3/14:22:31:54 Илия ИЛИЯ-VAIO PageOpen LicenseDialog 2013/3/14:22:31:58 Илия ИЛИЯ-VAIO PageOpen ProductInfoDialog 2013/3/14:22:32:13 Илия ИЛИЯ-VAIO PageOpen ProductSelectionDialog2 2013/3/14:22:32:22 Илия ИЛИЯ-VAIO PageOpen FullProgressDialog 2013/3/14:22:32:22 Илия ИЛИЯ-VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/3/14:22:32:26 Илия ИЛИЯ-VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/3/14:22:32:26 Илия ИЛИЯ-VAIO Installing DirectX Runtime: C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/14:22:32:52 Илия ИЛИЯ-VAIO Install DirectX Runtime Succeeded 2013/3/14:22:32:53 Илия ИЛИЯ-VAIO Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\x64\ru-ru\ACA\ACA.mst;C:\Users\36E3~1\AppData\Local\Temp\_AI621D.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_ACA_2013_Russian_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/3/14:22:35:47 Илия ИЛИЯ-VAIO Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603 2013/3/14:22:35:47 Илия ИЛИЯ-VAIO Rollback DirectX Runtime Failed Failure is ignored, Result=1619
