Hi there
I use AutoCAD and Revit, both 2011 and want to deploy it trough GPO to many Clients.
I used the build-in deployment-function, when you start setup.exe and created an installation.
Now EXCACTLY which MSI and MST I have to use?
Have you reviewed the step-by-step instructions for this process in the documentation?
AutoCAD 2011 Use Group Policies to Run a Deployment (online)
Revit Architecture 2011 Use Group Policies to Assign a Deployment to Computers (local HDD)
The location and name of these files will be based on your deployment name.
Revit Architecture 2011 Example:
<deployment name>\AdminImage\RevitSetup\RevitArchitecture\Autodesk Revit x64.msi
<deployment name>\AdminImage\RevitSetup\RevitArchitecture\Autodesk Revit x64-<deployment name>.mst
<deployment name>\Tools\gpo.mst
Hi
I tried it, it doesnt work 😞
Is there a log-file that I can post?
On the client machines did you first install the required components like DirectX and .Net Framework?
A log file does not get created with GPO as the system is doing the install not a user, but you can enable it by this Microsoft document. http://support.microsoft.com/kb/223300
Also on the client check the Windows Event Viewer for error, the the required components are missing as mentioned above the error will be about DirectX missing.
