Installation & Licensing
Autodesk Application Manager causes VoIP cutout every 10 seconds
4 REPLIES 4
TravisNave
1998 Views, 4 Replies
Problem:  When using a VoIP application on your computer where Autodesk Application Manager is installed, phone conversations cut out momentarily every 10 seconds.
Cause:  Possible causes may be linked to a keep-alive check that affects QoS on the host machine.  More research will be required.
Work-Around:  After adjusting many settings and upgrading to the latest version (to date: v2.2 April 2, 2014) did not alleviate the issue.  Therefore, the only solution is to exit the application from the systray.  Subsequently, changing the setting to not autostart with Windows or removing it with msconfig are other alternatives.
For more information about this product, please see this link:
https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Aautodeska...
I will try to monitor this issue as more testing occurs.  However, with the increase of VoIP, I felt it necessary to provide this information.
Thanks.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
4 REPLIES 4
david.lau
in reply to: TravisNave
Just an FYI, the Application Manager is different from the App Manager.
Application Manager = Manages updates [Service Packs]
App Manager = App plug-in can be used with AutoCAD to simplify the process of managing apps installed from Exchange.
David Lau
DarrenP
in reply to: david.lau
Travis
I think you mean this link: www.autodesk.com/applicationmanager
DarrenP
TravisNave
Thanks guys, I inadvertently grabbed the wrong link when I did the search.  Of course, my complaint for years on the forums have been the inability to go back and edit posts.
But yes, the Application Manager with filename of AdAppMgr.exe is the correct reference to the OP.  Thanks again for the clarification.
Autodesk Forums:
Thanks for reporting the problem. There is a bug logged. Will look into it.
Krishna
Autodesk Application Manager Team
Administrator Productivity
