I'm at my wits end trying to install AAA2012 with GPO. I can't use the setup.exe for a number of reasons so I need to get this working using GPO.
I've created a deployment including all the products. All that gives me is admin image that is apparently meant to be installed using setup.exe which caused a load of problems with my deployment solution (Specops Deploy). It DOES work when used manually though.
Is there really no way to get an MSI-based admin image like with VIZ2008 / Autocad? Or some other way of using the MSI:s that the deployment wizard creates. The Network Admin Guide just keeps refering to Autocad, it doesn't seem to be updated for AAA2012....
Sorry, each individual product's MSI files needs to be added to the GPO (similar to the AutoCAD documentation).
there is no single MSI for the AAA 2012 to deploy all the products.
I too am interested in using a GPO to install AAA2011. I can't seem to get past "Creating an original deployment", because the instructions don't match what I'm seeing when I insert the DVD and start the install. Am I missing someting? Does someone have a "recipe" for doing this? If so, please share or point me at where I can find it. Thanks!
George
