Installation & Licensing
Autodesk Activation window broken
4 REPLIES 4
scorch267
378 Views, 4 Replies
when ever I try and activate MAYA the doesn't load properly and all i see is this. have tried redownloading and reinstalling but to no avail. any ideas?
4 REPLIES 4
joane.bonghanoy
in reply to: scorch267
Hi scorch267,
Please click here for the resolution of this error.
Let us know if it worked for you or if you still have the same issue.
Joane Bonghanoy
scorch267
in reply to: joane.bonghanoy
I have tried all the suggestions (except number 1 because IE8 isn't available on windows 7) and nothing has worked. I am now trying IE10 and will get back to you.
TravisNave
Others have had success from the multiple items in this post:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Forums:
scorch267
in reply to: TravisNave
Updating to IE 10 fixed the problem thankyou for the help.
Administrator Productivity
