Hi guys,
I'm currently getting lot's of software because I'm in architecture. I really need them for modelisation, conception and other things. So I'd like to install Autodesk 3ds Max Design 2015 on my computer (PC Windows 8.1).
First of all, it's important to say that I've already install several Autodesk products like Maya 2015, Revit, Autocad 2015, Autocad 2015 Architecture.
However I've got a big problem with the installation of this one, so when I launch the entire installation of the software (I mean that there is automatically the downloading of the installation file and then the installation (online) with this file), there is after 5 minutes of installation a message error :
2014/11/29:01:17:33 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:01:17:33 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:01:17:33 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:01:17:33 Tristan PC-TRISTAN Launch
2014/11/29:01:17:33 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:01:17:33 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI7BC5.tmp
2014/11/29:01:18:22 Tristan PC-TRISTAN === Setup ended ===
2014/11/29:01:17:35 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:01:17:35 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:01:17:35 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI7BC5.tmp
2014/11/29:01:17:35 Tristan PC-TRISTAN Launch
2014/11/29:01:17:39 Tristan PC-TRISTAN Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:01:18:21 Tristan PC-TRISTAN Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:01:18:22 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/11/29:01:18:40 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/11/29:01:18:40 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/11/29:01:18:40 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/11/29:01:18:46 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/11/29:01:18:47 Tristan PC-TRISTAN Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:18:55 Tristan PC-TRISTAN Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:18:55 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:01:19:10 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/11/29:01:19:11 Tristan PC-TRISTAN Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:19:19 Tristan PC-TRISTAN Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:19:19 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:01:19:20 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/11/29:01:19:20 Tristan PC-TRISTAN Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:01:19:28 Tristan PC-TRISTAN Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:01:19:28 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:01:19:36 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/11/29:01:19:36 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:01:32:27 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:01:32:27 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/11/29:01:32:27 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/29:01:32:28 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/11/29:01:32:28 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/11/29:01:32:32 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/11/29:02:03:40 Tristan PC-TRISTAN === Setup ended ===
2014/11/29:14:26:38 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:14:26:38 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:14:26:38 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:14:26:38 Tristan PC-TRISTAN Launch
2014/11/29:14:26:38 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:14:26:38 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIE600.tmp
2014/11/29:14:26:43 Tristan PC-TRISTAN === Setup ended ===
2014/11/29:14:26:39 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:14:26:39 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:14:26:39 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIE600.tmp
2014/11/29:14:26:39 Tristan PC-TRISTAN Launch
2014/11/29:14:26:42 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:14:26:42 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/11/29:14:26:49 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/11/29:14:26:49 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/11/29:14:26:49 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/11/29:14:27:56 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/11/29:14:27:57 Tristan PC-TRISTAN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:14:27:57 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:14:28:02 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/11/29:14:28:02 Tristan PC-TRISTAN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:14:28:02 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:14:28:02 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/11/29:14:28:02 Tristan PC-TRISTAN Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:14:28:02 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:14:28:08 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/11/29:14:28:09 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:14:39:50 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:14:39:50 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/11/29:14:39:52 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/29:14:39:52 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/11/29:14:39:52 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/11/29:14:39:56 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/11/29:15:05:06 Tristan PC-TRISTAN === Setup ended ===
2014/11/29:15:08:26 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:15:08:26 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:15:08:26 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:15:08:26 Tristan PC-TRISTAN Launch
2014/11/29:15:08:26 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:15:08:26 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI2E5B.tmp
2014/11/29:15:08:34 Tristan PC-TRISTAN === Setup ended ===
2014/11/29:15:08:28 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:15:08:28 Tristan PC-TRISTAN Path_Length: 155
2014/11/29:15:08:28 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI2E5B.tmp
2014/11/29:15:08:28 Tristan PC-TRISTAN Launch
2014/11/29:15:08:30 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:15:08:32 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/11/29:15:08:49 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/11/29:15:08:49 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/11/29:15:08:49 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/11/29:15:08:53 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/11/29:15:08:54 Tristan PC-TRISTAN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:15:08:54 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:15:08:59 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/11/29:15:09:00 Tristan PC-TRISTAN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:15:09:00 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:15:09:01 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/11/29:15:09:01 Tristan PC-TRISTAN Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:15:09:01 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:15:09:10 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/11/29:15:09:11 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:15:20:13 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:15:20:13 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/11/29:15:20:14 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/29:15:20:14 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/11/29:15:20:14 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/11/29:15:20:17 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/11/29:15:21:10 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:02:15:44 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:15:44 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:02:15:44 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:02:15:44 Tristan PC-TRISTAN Launch
2014/12/6:02:15:44 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:02:15:44 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6BFA.tmp
2014/12/6:02:16:46 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:02:15:47 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:15:47 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:02:15:47 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6BFA.tmp
2014/12/6:02:15:47 Tristan PC-TRISTAN Launch
2014/12/6:02:15:51 Tristan PC-TRISTAN Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:16:45 Tristan PC-TRISTAN Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:16:46 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:02:26:00 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:02:26:00 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/6:02:26:00 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/6:02:26:07 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/6:02:26:09 Tristan PC-TRISTAN Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:15 Tristan PC-TRISTAN Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:15 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:02:26:23 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/6:02:26:24 Tristan PC-TRISTAN Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:31 Tristan PC-TRISTAN Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:31 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:02:26:31 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/6:02:26:32 Tristan PC-TRISTAN Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:02:26:37 Tristan PC-TRISTAN Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:02:26:37 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:02:26:41 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/12/6:02:26:42 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:02:39:26 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:02:39:26 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/12/6:02:39:28 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/6:02:39:28 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/6:02:39:28 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/6:02:39:31 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/12/6:02:46:26 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:02:58:36 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:58:36 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:02:58:36 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:02:58:36 Tristan PC-TRISTAN Launch
2014/12/6:02:58:36 Tristan PC-TRISTAN CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:02:58:36 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIA79E.tmp
2014/12/6:02:58:54 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:02:58:38 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:58:38 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:02:58:38 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIA79E.tmp
2014/12/6:02:58:38 Tristan PC-TRISTAN Launch
2014/12/6:02:58:43 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:58:46 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:02:59:07 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:03:07:14 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/6:03:07:14 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/6:03:07:18 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/6:03:07:19 Tristan PC-TRISTAN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:03:07:19 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:03:07:31 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/6:03:07:31 Tristan PC-TRISTAN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:03:07:31 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:03:07:33 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/6:03:07:33 Tristan PC-TRISTAN Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:03:07:33 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:03:07:42 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/12/6:03:07:43 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:03:19:07 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:03:19:07 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/12/6:03:19:08 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/6:03:19:08 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/6:03:19:09 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/6:03:19:12 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/12/6:03:36:09 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:12:18:40 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:18:40 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:12:18:40 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:12:18:40 Tristan PC-TRISTAN Launch
2014/12/6:12:18:40 Tristan PC-TRISTAN CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:12:18:40 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6B9F.tmp
2014/12/6:12:18:57 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:12:18:42 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:18:42 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:12:18:42 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6B9F.tmp
2014/12/6:12:18:42 Tristan PC-TRISTAN Launch
2014/12/6:12:18:44 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:12:18:46 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:12:25:41 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:12:27:10 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:12:27:32 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:27:32 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:12:27:32 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:12:27:32 Tristan PC-TRISTAN Launch
2014/12/6:12:27:32 Tristan PC-TRISTAN CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:12:27:32 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI87AC.tmp
2014/12/6:12:27:42 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:12:27:33 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:27:33 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:12:27:33 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI87AC.tmp
2014/12/6:12:27:33 Tristan PC-TRISTAN Launch
2014/12/6:12:27:35 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:12:27:36 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:12:28:08 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:12:28:13 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/6:12:28:13 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/6:12:28:16 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/6:12:28:17 Tristan PC-TRISTAN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:12:28:17 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:12:28:29 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/6:12:28:29 Tristan PC-TRISTAN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:12:28:29 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:12:28:30 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/6:12:28:30 Tristan PC-TRISTAN Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:12:28:30 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:12:28:41 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/12/6:12:28:43 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:12:39:46 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:12:39:46 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/12/6:12:39:47 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/6:12:39:47 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/6:12:39:47 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/6:12:39:50 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/12/6:12:46:16 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:13:03:50 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:13:03:50 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:13:03:50 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:13:03:50 Tristan PC-TRISTAN Launch
2014/12/6:13:03:50 Tristan PC-TRISTAN CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:13:03:50 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIC4B5.tmp
2014/12/6:13:03:57 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:13:03:52 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:13:03:52 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:13:03:52 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIC4B5.tmp
2014/12/6:13:03:52 Tristan PC-TRISTAN Launch
2014/12/6:13:03:52 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:13:03:54 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:13:04:20 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:13:06:04 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/6:13:06:04 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/6:13:06:08 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/6:13:06:08 Tristan PC-TRISTAN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:13:06:08 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:13:06:19 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/6:13:06:20 Tristan PC-TRISTAN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:13:06:20 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:13:06:21 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/6:13:06:21 Tristan PC-TRISTAN Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:13:06:21 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:13:06:31 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/12/6:13:06:31 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:13:19:06 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:13:19:06 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/12/6:13:19:06 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/6:13:19:06 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/6:13:19:06 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/6:13:19:08 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/12/6:13:35:23 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:15:43:40 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:43:40 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:15:43:40 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI34AE.tmp
2014/12/6:15:43:40 Tristan PC-TRISTAN Launch
2014/12/6:15:43:44 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:15:43:38 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:43:38 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:15:43:38 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:15:43:38 Tristan PC-TRISTAN Launch
2014/12/6:15:43:38 Tristan PC-TRISTAN CommandLine
2014/12/6:15:43:38 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI34AE.tmp
2014/12/6:15:43:47 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:15:48:12 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:48:12 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:15:48:12 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:15:48:12 Tristan PC-TRISTAN Launch
2014/12/6:15:48:12 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:15:48:12 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6159.tmp
2014/12/6:15:48:55 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:15:48:14 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:48:14 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:15:48:14 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6159.tmp
2014/12/6:15:48:14 Tristan PC-TRISTAN Launch
2014/12/6:15:48:15 Tristan PC-TRISTAN Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:15:48:53 Tristan PC-TRISTAN Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:15:48:56 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:16:25:22 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:17:35:43 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:17:35:43 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:17:35:43 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:17:35:43 Tristan PC-TRISTAN Launch
2014/12/6:17:35:43 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:17:35:43 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AID302.tmp
2014/12/6:17:36:29 Tristan PC-TRISTAN === Setup ended ===
2014/12/6:17:35:44 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:17:35:44 Tristan PC-TRISTAN Path_Length: 155
2014/12/6:17:35:44 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AID302.tmp
2014/12/6:17:35:44 Tristan PC-TRISTAN Launch
2014/12/6:17:35:52 Tristan PC-TRISTAN Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:17:36:29 Tristan PC-TRISTAN Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:17:36:29 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/6:17:37:58 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/6:17:37:58 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/6:17:37:58 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/6:17:42:20 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/6:17:42:21 Tristan PC-TRISTAN Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:42:29 Tristan PC-TRISTAN Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:42:29 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/12/6:17:42:39 Tristan PC-TRISTAN Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/12/6:17:42:40 Tristan PC-TRISTAN Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:43:51 Tristan PC-TRISTAN Download Error VCREDIST2012X86 <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant? http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:45:01 Tristan PC-TRISTAN Download User Resume VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:45:31 Tristan PC-TRISTAN Download Error VCREDIST2012X86 <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant? http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:48:34 Tristan PC-TRISTAN Download User Resume VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:06 Tristan PC-TRISTAN Download Error VCREDIST2012X86 <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant? http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:08 Tristan PC-TRISTAN Download User Cancel VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:08 Tristan PC-TRISTAN Download Aborted VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:09 Tristan PC-TRISTAN PageOpen InstallCompleteDialog
2014/12/6:17:49:13 Tristan PC-TRISTAN === Setup ended ===
2014/12/7:00:48:22 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/7:00:48:22 Tristan PC-TRISTAN Path_Length: 155
2014/12/7:00:48:22 Tristan PC-TRISTAN Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/7:00:48:22 Tristan PC-TRISTAN Launch
2014/12/7:00:48:22 Tristan PC-TRISTAN CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/7:00:48:22 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIEB75.tmp
2014/12/7:00:48:28 Tristan PC-TRISTAN === Setup ended ===
2014/12/7:00:48:23 Tristan PC-TRISTAN === Setup started on PC-TRISTAN by Tristan ===
2014/12/7:00:48:23 Tristan PC-TRISTAN Path_Length: 155
2014/12/7:00:48:23 Tristan PC-TRISTAN Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIEB75.tmp
2014/12/7:00:48:23 Tristan PC-TRISTAN Launch
2014/12/7:00:48:25 Tristan PC-TRISTAN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/7:00:48:26 Tristan PC-TRISTAN PageOpen LaunchDialog
2014/12/7:00:54:47 Tristan PC-TRISTAN PageOpen LicenseDialog
2014/12/7:00:54:47 Tristan PC-TRISTAN PageOpen ProductInfoDialog
2014/12/7:00:54:47 Tristan PC-TRISTAN PageOpen ProductSelectionDialog2
2014/12/7:00:55:30 Tristan PC-TRISTAN PageOpen FullProgressDialog
2014/12/7:00:55:31 Tristan PC-TRISTAN Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:55:39 Tristan PC-TRISTAN Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:55:39 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/7:00:56:24 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/7:00:56:24 Tristan PC-TRISTAN Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:56:33 Tristan PC-TRISTAN Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:56:33 Tristan PC-TRISTAN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/7:00:56:34 Tristan PC-TRISTAN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/7:00:56:35 Tristan PC-TRISTAN Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/7:00:56:43 Tristan PC-TRISTAN Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/7:00:56:43 Tristan PC-TRISTAN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/7:00:56:52 Tristan PC-TRISTAN Install DirectX® Runtime Succeeded
2014/12/7:00:56:53 Tristan PC-TRISTAN Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/7:01:08:20 Tristan PC-TRISTAN Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/7:01:08:20 Tristan PC-TRISTAN Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/12/7:01:08:21 Tristan PC-TRISTAN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/7:01:08:21 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/7:01:08:21 Tristan PC-TRISTAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
After many search, I don't find any solution, and Autodesk support for installation wasn't usefull.
Is there any link with my ports? For example mental ray? Don't think so because it's the same support for all software and before this one I didn't met this problem...
Help me please
I'm french 🙂 (and got the student version)
Thank you
It is failing to download.
You might try the trial or see if you can download from the virtual agent. I am not 100% sure that you can get the French version or not.
