Installation & Licensing
Autodesk 3ds Max Design - problem with installation
1 REPLY 1
Shepard69
339 Views, 1 Reply
Hi guys,
I'm currently getting lot's of software because I'm in architecture. I really need them for modelisation, conception and other things. So I'd like to install Autodesk 3ds Max Design 2015 on my computer (PC Windows 8.1).
First of all, it's important to say that I've already install several Autodesk products like Maya 2015, Revit, Autocad 2015, Autocad 2015 Architecture.
However I've got a big problem with the installation of this one, so when I launch the entire installation of the software (I mean that there is automatically the downloading of the installation file and then the installation (online) with this file), there is after 5 minutes of installation a message error :
2014/11/29:01:17:33    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:01:17:33    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:01:17:33    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:01:17:33    Tristan    PC-TRISTAN    Launch
2014/11/29:01:17:33    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:01:17:33    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI7BC5.tmp
2014/11/29:01:18:22    Tristan    PC-TRISTAN    === Setup ended ===
2014/11/29:01:17:35    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:01:17:35    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:01:17:35    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI7BC5.tmp
2014/11/29:01:17:35    Tristan    PC-TRISTAN    Launch
2014/11/29:01:17:39    Tristan    PC-TRISTAN    Download    Play    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:01:18:21    Tristan    PC-TRISTAN    Download    Complete    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:01:18:22    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/11/29:01:18:40    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/11/29:01:18:40    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/11/29:01:18:40    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/11/29:01:18:46    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/11/29:01:18:47    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:18:55    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:18:55    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:01:19:10    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/11/29:01:19:11    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:19:19    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:01:19:19    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:01:19:20    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/11/29:01:19:20    Tristan    PC-TRISTAN    Download    Play    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:01:19:28    Tristan    PC-TRISTAN    Download    Complete    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:01:19:28    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:01:19:36    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/11/29:01:19:36    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:01:32:27    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:01:32:27    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/11/29:01:32:27    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/11/29:01:32:28    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/11/29:01:32:28    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/11/29:01:32:32    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/11/29:02:03:40    Tristan    PC-TRISTAN    === Setup ended ===
2014/11/29:14:26:38    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:14:26:38    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:14:26:38    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:14:26:38    Tristan    PC-TRISTAN    Launch
2014/11/29:14:26:38    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:14:26:38    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIE600.tmp
2014/11/29:14:26:43    Tristan    PC-TRISTAN    === Setup ended ===
2014/11/29:14:26:39    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:14:26:39    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:14:26:39    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIE600.tmp
2014/11/29:14:26:39    Tristan    PC-TRISTAN    Launch
2014/11/29:14:26:42    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:14:26:42    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/11/29:14:26:49    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/11/29:14:26:49    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/11/29:14:26:49    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/11/29:14:27:56    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/11/29:14:27:57    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:14:27:57    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Download    Skipped    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:14:28:02    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:14:28:08    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/11/29:14:28:09    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:14:39:50    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:14:39:50    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/11/29:14:39:52    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/11/29:14:39:52    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/11/29:14:39:52    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/11/29:14:39:56    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/11/29:15:05:06    Tristan    PC-TRISTAN    === Setup ended ===
2014/11/29:15:08:26    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:15:08:26    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:15:08:26    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/11/29:15:08:26    Tristan    PC-TRISTAN    Launch
2014/11/29:15:08:26    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/11/29:15:08:26    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI2E5B.tmp
2014/11/29:15:08:34    Tristan    PC-TRISTAN    === Setup ended ===
2014/11/29:15:08:28    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/11/29:15:08:28    Tristan    PC-TRISTAN    Path_Length: 155
2014/11/29:15:08:28    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI2E5B.tmp
2014/11/29:15:08:28    Tristan    PC-TRISTAN    Launch
2014/11/29:15:08:30    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/11/29:15:08:32    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/11/29:15:08:49    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/11/29:15:08:49    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/11/29:15:08:49    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/11/29:15:08:53    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/11/29:15:08:54    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:15:08:54    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/29:15:08:59    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/11/29:15:09:00    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/11/29:15:09:00    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/29:15:09:01    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/11/29:15:09:01    Tristan    PC-TRISTAN    Download    Skipped    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/11/29:15:09:01    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/29:15:09:10    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/11/29:15:09:11    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:15:20:13    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/11/29:15:20:13    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/11/29:15:20:14    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/11/29:15:20:14    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/11/29:15:20:14    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/11/29:15:20:17    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/11/29:15:21:10    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:02:15:44    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:15:44    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:02:15:44    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:02:15:44    Tristan    PC-TRISTAN    Launch
2014/12/6:02:15:44    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:02:15:44    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6BFA.tmp
2014/12/6:02:16:46    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:02:15:47    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:15:47    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:02:15:47    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6BFA.tmp
2014/12/6:02:15:47    Tristan    PC-TRISTAN    Launch
2014/12/6:02:15:51    Tristan    PC-TRISTAN    Download    Play    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:16:45    Tristan    PC-TRISTAN    Download    Complete    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:16:46    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:02:26:00    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:02:26:00    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/6:02:26:00    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/6:02:26:07    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/6:02:26:09    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:15    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:15    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:02:26:23    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/12/6:02:26:24    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:31    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:02:26:31    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:02:26:31    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/12/6:02:26:32    Tristan    PC-TRISTAN    Download    Play    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:02:26:37    Tristan    PC-TRISTAN    Download    Complete    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:02:26:37    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:02:26:41    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/12/6:02:26:42    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:02:39:26    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:02:39:26    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/12/6:02:39:28    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/12/6:02:39:28    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/12/6:02:39:28    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/12/6:02:39:31    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/12/6:02:46:26    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:02:58:36    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:58:36    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:02:58:36    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:02:58:36    Tristan    PC-TRISTAN    Launch
2014/12/6:02:58:36    Tristan    PC-TRISTAN    CommandLine    /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:02:58:36    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIA79E.tmp
2014/12/6:02:58:54    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:02:58:38    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:02:58:38    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:02:58:38    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIA79E.tmp
2014/12/6:02:58:38    Tristan    PC-TRISTAN    Launch
2014/12/6:02:58:43    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:02:58:46    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:02:59:07    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:03:07:14    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/6:03:07:14    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/6:03:07:18    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/6:03:07:19    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:03:07:19    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:03:07:31    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/12/6:03:07:31    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:03:07:31    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:03:07:33    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/12/6:03:07:33    Tristan    PC-TRISTAN    Download    Skipped    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:03:07:33    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:03:07:42    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/12/6:03:07:43    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:03:19:07    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:03:19:07    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/12/6:03:19:08    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/12/6:03:19:08    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/12/6:03:19:09    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/12/6:03:19:12    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/12/6:03:36:09    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:12:18:40    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:18:40    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:12:18:40    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:12:18:40    Tristan    PC-TRISTAN    Launch
2014/12/6:12:18:40    Tristan    PC-TRISTAN    CommandLine    /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:12:18:40    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6B9F.tmp
2014/12/6:12:18:57    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:12:18:42    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:18:42    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:12:18:42    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6B9F.tmp
2014/12/6:12:18:42    Tristan    PC-TRISTAN    Launch
2014/12/6:12:18:44    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:12:18:46    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:12:25:41    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:12:27:10    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:12:27:32    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:27:32    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:12:27:32    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:12:27:32    Tristan    PC-TRISTAN    Launch
2014/12/6:12:27:32    Tristan    PC-TRISTAN    CommandLine    /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:12:27:32    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI87AC.tmp
2014/12/6:12:27:42    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:12:27:33    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:12:27:33    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:12:27:33    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI87AC.tmp
2014/12/6:12:27:33    Tristan    PC-TRISTAN    Launch
2014/12/6:12:27:35    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:12:27:36    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:12:28:08    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:12:28:13    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/6:12:28:13    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/6:12:28:16    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/6:12:28:17    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:12:28:17    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:12:28:29    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/12/6:12:28:29    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:12:28:29    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:12:28:30    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/12/6:12:28:30    Tristan    PC-TRISTAN    Download    Skipped    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:12:28:30    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:12:28:41    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/12/6:12:28:43    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:12:39:46    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:12:39:46    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/12/6:12:39:47    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/12/6:12:39:47    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/12/6:12:39:47    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/12/6:12:39:50    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/12/6:12:46:16    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:13:03:50    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:13:03:50    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:13:03:50    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:13:03:50    Tristan    PC-TRISTAN    Launch
2014/12/6:13:03:50    Tristan    PC-TRISTAN    CommandLine    /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /skipPI /SN 900-52037989 /PK 495G1 /akamai
2014/12/6:13:03:50    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIC4B5.tmp
2014/12/6:13:03:57    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:13:03:52    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:13:03:52    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:13:03:52    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIC4B5.tmp
2014/12/6:13:03:52    Tristan    PC-TRISTAN    Launch
2014/12/6:13:03:52    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:13:03:54    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:13:04:20    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:13:06:04    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/6:13:06:04    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/6:13:06:08    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/6:13:06:08    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:13:06:08    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/6:13:06:19    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/12/6:13:06:20    Tristan    PC-TRISTAN    Download    Skipped    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:13:06:20    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/6:13:06:21    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/12/6:13:06:21    Tristan    PC-TRISTAN    Download    Skipped    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/6:13:06:21    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/6:13:06:31    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/12/6:13:06:31    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:13:19:06    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/6:13:19:06    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/12/6:13:19:06    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/12/6:13:19:06    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/12/6:13:19:06    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/12/6:13:19:08    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/12/6:13:35:23    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:15:43:40    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:43:40    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:15:43:40    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI34AE.tmp
2014/12/6:15:43:40    Tristan    PC-TRISTAN    Launch
2014/12/6:15:43:44    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:15:43:38    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:43:38    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:15:43:38    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:15:43:38    Tristan    PC-TRISTAN    Launch
2014/12/6:15:43:38    Tristan    PC-TRISTAN    CommandLine
2014/12/6:15:43:38    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI34AE.tmp
2014/12/6:15:43:47    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:15:48:12    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:48:12    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:15:48:12    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:15:48:12    Tristan    PC-TRISTAN    Launch
2014/12/6:15:48:12    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:15:48:12    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6159.tmp
2014/12/6:15:48:55    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:15:48:14    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:15:48:14    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:15:48:14    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AI6159.tmp
2014/12/6:15:48:14    Tristan    PC-TRISTAN    Launch
2014/12/6:15:48:15    Tristan    PC-TRISTAN    Download    Play    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:15:48:53    Tristan    PC-TRISTAN    Download    Complete    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:15:48:56    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:16:25:22    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:17:35:43    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:17:35:43    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:17:35:43    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/6:17:35:43    Tristan    PC-TRISTAN    Launch
2014/12/6:17:35:43    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/6:17:35:43    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AID302.tmp
2014/12/6:17:36:29    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/6:17:35:44    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/6:17:35:44    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/6:17:35:44    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AID302.tmp
2014/12/6:17:35:44    Tristan    PC-TRISTAN    Launch
2014/12/6:17:35:52    Tristan    PC-TRISTAN    Download    Play    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:17:36:29    Tristan    PC-TRISTAN    Download    Complete    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/6:17:36:29    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/6:17:37:58    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/6:17:37:58    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/6:17:37:58    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/6:17:42:20    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/6:17:42:21    Tristan    PC-TRISTAN    Download    Play    VCREDIST2010SP1X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:42:29    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2010SP1X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:42:29    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/12/6:17:42:39    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2014/12/6:17:42:40    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:43:51    Tristan    PC-TRISTAN    Download Error    VCREDIST2012X86    <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant?     http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:45:01    Tristan    PC-TRISTAN    Download    User Resume    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:45:31    Tristan    PC-TRISTAN    Download Error    VCREDIST2012X86    <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant?     http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:48:34    Tristan    PC-TRISTAN    Download    User Resume    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:06    Tristan    PC-TRISTAN    Download Error    VCREDIST2012X86    <B>Erreur réseau. Téléchargement impossible</B>Vérifiez les connexions et réessayez. Voulez-vous réessayer maintenant?     http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:08    Tristan    PC-TRISTAN    Download    User Cancel    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:08    Tristan    PC-TRISTAN    Download    Aborted    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/6:17:49:09    Tristan    PC-TRISTAN    PageOpen    InstallCompleteDialog
2014/12/6:17:49:13    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/7:00:48:22    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/7:00:48:22    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/7:00:48:22    Tristan    PC-TRISTAN    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_R2_wi_fr-FR
2014/12/7:00:48:22    Tristan    PC-TRISTAN    Launch
2014/12/7:00:48:22    Tristan    PC-TRISTAN    CommandLine    /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_... /SN 900-52037989 /PK 495G1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/7:00:48:22    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIEB75.tmp
2014/12/7:00:48:28    Tristan    PC-TRISTAN    === Setup ended ===
2014/12/7:00:48:23    Tristan    PC-TRISTAN    === Setup started on PC-TRISTAN by Tristan ===
2014/12/7:00:48:23    Tristan    PC-TRISTAN    Path_Length: 155
2014/12/7:00:48:23    Tristan    PC-TRISTAN    Current Directory C:\Users\Tristan\AppData\Local\Temp\_AIEB75.tmp
2014/12/7:00:48:23    Tristan    PC-TRISTAN    Launch
2014/12/7:00:48:25    Tristan    PC-TRISTAN    Download    Skipped    SETUP_CONFIG    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2014/12/7:00:48:26    Tristan    PC-TRISTAN    PageOpen    LaunchDialog
2014/12/7:00:54:47    Tristan    PC-TRISTAN    PageOpen    LicenseDialog
2014/12/7:00:54:47    Tristan    PC-TRISTAN    PageOpen    ProductInfoDialog
2014/12/7:00:54:47    Tristan    PC-TRISTAN    PageOpen    ProductSelectionDialog2
2014/12/7:00:55:30    Tristan    PC-TRISTAN    PageOpen    FullProgressDialog
2014/12/7:00:55:31    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:55:39    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X86    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:55:39    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/7:00:56:24    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/12/7:00:56:24    Tristan    PC-TRISTAN    Download    Play    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:56:33    Tristan    PC-TRISTAN    Download    Complete    VCREDIST2012X64    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2014/12/7:00:56:33    Tristan    PC-TRISTAN    Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/7:00:56:34    Tristan    PC-TRISTAN    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/12/7:00:56:35    Tristan    PC-TRISTAN    Download    Play    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/7:00:56:43    Tristan    PC-TRISTAN    Download    Complete    DIRECTX    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2014/12/7:00:56:43    Tristan    PC-TRISTAN    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/7:00:56:52    Tristan    PC-TRISTAN    Install    DirectX® Runtime    Succeeded
2014/12/7:00:56:53    Tristan    PC-TRISTAN    Download    Play    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/7:01:08:20    Tristan    PC-TRISTAN    Download    Aborted    CMILM    http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2014/12/7:01:08:20    Tristan    PC-TRISTAN    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Failed    Download Failed, Installation aborted, Result=1603
2014/12/7:01:08:21    Tristan    PC-TRISTAN    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/12/7:01:08:21    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/12/7:01:08:21    Tristan    PC-TRISTAN    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
After many search, I don't find any solution, and Autodesk support for installation wasn't usefull.
Is there any link with my ports? For example mental ray? Don't think so because it's the same support for all software and before this one I didn't met this problem...
Help me please
I'm french 🙂 (and got the student version)
Thank you
1 REPLY 1
TravisNave
in reply to: Shepard69
 It is failing to download.
You might try the trial or see if you can download from the virtual agent.  I am not 100% sure that you can get the French version or not.
Autodesk Forums:
Administrator Productivity
