Installation & Licensing
Autodesk 3ds Max 2011 Activation Problem
4 REPLIES 4
stephen.cruzmarshall
7326 Views, 4 Replies
When attempting to activate Autodesk 3ds Max 2011, I open the program after downloading and click on the "activate" button at the lower right hand corner. After click that Autodesk Claims that there is the request code at the top but when it appears I get a blank box that has two different selection bubbles and that's it. Is there anyway I can get the request code an alternative way or fix the issues regarding the activation screen?
I will attach a picture of what the screen looks like
Thank you for any help that can be provided
4 REPLIES 4
Here is our official solution, please try it: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Emily Xu
Product Support
zens6
in reply to: emily.xu
emily.xu
in reply to: zens6
Sometimes, when you try to regsvr32 a module in normal command prompt window without proper administrative privileges, you will get the following error message:
The module “xxx.dll” was loaded but the call to DllregisterServer failed with error code 0×80004005.
To solve the call to “DllregisterServer failed with error code 0×80004005″ error,run a Command Prompt as Administrator. Alternatively, you can disable User Access Control too, or login with Administrator account.
good luck!
Emily Xu
Product Support
Thank you,
The window is now functional. and everything I need for activation is there.
Thanks agian,
~Stephen
Administrator Productivity
