My users have very specific user names and wish for Autodesk 360 to stop changing the user name when they log into Autodesk 360. Is there a way can Stop 360 from changing our user names? It is one thing to track the way the program is working but it is another thing when you change our computers setting. There should be a way for stopping this from happening.
Solved by RevitVicar. Go to Solution.
When my users are in Revit 2015 and they go to do a rendering they need to log into Autodesk 360 in the communications bar, When the user logs in it changes the user name in the options window for Revit. This is causing problems.
We had a discussion on this exact topic over on RevitForums. I'd recommend that you take a look at that thread first, and then post any additional comments or concerns here.
Cheers,
Kyle
Chris,
As noted in the linked forum discussion, signing into your Autodesk Identity within Revit aligns your worksharing identity to match your Autodesk identity. This was done to enable a consistent identity of team members across all the activities they carry out in the Autodesk 360 ecosystem. You have 3 options here:
-Kyle
Chris,
Sorry this change frustrates you. As noted previously, your firm is welcome to continue with your current practice for worksharing identities. Nobody is forcing you to utilize Autodesk 360 services.
A consistent identity across all activities by a user a very important part of an experience for the entire team, so everybody knows who is doing what within the project from renders, to model changes, to energy analyses. With our pending release of Project Skyscraper, extending that consistent identity to worksharing operations was necessary. We understood at the time that there would be disruption to existing practices, and ultimately decided that the long-term future of constsent identities across activities was a greater overall benefit to the project team.
-Kyle
Point (3) isn't supportable. Consider that there are many different users of the product, all with their individual needs and procedures. Changing the product to support your specific procedures will undoubtedly create the similar problems with at least as many if not more users. So now there are many competing concepts fighting for dominance. No matter which way AutoDesk leans they will disappoint at least some of their user base and in this particular instance it happens to be you.
The role of the software developer when creating a product for general sale is to attempt to find a good common ground that everybody can play in. Many times this will involve everybody having to make a few changes in order to make use of the product. With the software being offered as-is we don't have direct input to the development process - the best we can hope for is to make a supportable case which will benefit most of the users of the product. The only other option is to do work-for-hire, that is hire a developer with a specific set of criteria that must be met.
I understand the three advices that you gave us. What I would like to know is how to re set my system to match the computer name, as was before, in stead of the Autodes 360. Thanks
Signing out of Autodesk 360 from the Revit InfoCenter will return the Worksharing Username to a editable state, at which point you can change the Username back to whatever it was previously.
-Kyle
If this is the answer I will be uninstalling AutDesk 360.
This changing of the Revit username is causing me to not use Autodesk 360.
