Installation & Licensing
Autodesk 2015 Products + Latest NLM [11.12]
7 REPLIES 7
Message 1 of 8
DarrenP
1798 Views, 7 Replies
If you are using a network license of your Autodesk 2015 product, you MUSTupdate to NLM [Network License Manager] 11.12 in order for the software to get the license from the license server. The 2015 clients cannot get licenses from a server running NLM 11.11 or lower.
DarrenP
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: DarrenP
Thank the Up & Ready Blog guys for this tip
http://upandready.typepad.com/up_and_ready/2014/03/autodesk-2015-products-latest-nlm-1112.html?utm_s...
DarrenP
Message 3 of 8
TravisNave
Darren,
I was able to get it to pull from 11.7.  This is an odd admission by Autodesk.
Autodesk Forums:
Message 4 of 8
DarrenP
in reply to: TravisNave
maybe it depends on the product
DarrenP
Message 5 of 8
ellyn
Hi Travis,
Could you please include the link where I could download the 11.7 version to run on 2003 server, i keep getting an error adskflex exited with status 128 in the log file.  I have downloaded and used 11.12.  thanks.
Message 6 of 8
TravisNave
in reply to: ellyn
You can get the 32-bit adskflex.exe vendor daemon file for 11.7 attached to my forum post here:
http://forums.autodesk.com/t5/installation-licensing/autodesk-network-license-manager-2014/m-p/38199...
Use it on Server 2003.  The rest of the license manager can stay 11.12 if you like.  Though all of 11.12 should work fine on Server 2003.
Autodesk Forums:
Message 7 of 8
Hi Travis,
That's what I thought too 'cause,  it worked before, same configuration, same version, when I first installed last July, only the server crashed that I had to reinstall soon as the old server got restored.
I'm also looking at the any possibility that perhaps, the system(microsoft) needs service pack updates, and its not even a corrupted download because the same version of nlm (v11.12) which I've downloaded and installed, worked on a new pc/license server.
Thanks for the inputs.
Message 8 of 8
TravisNave
Right.  Your logs show that the master daemon is firing fine on 11.12, but the adskflex.exe is not.  You could try the 32-bit adskflex and see if it fixes the issue.  Additonally, the adskflex.exe will never fire off if there is an inconsistency in your license file.  Might double-check all of your bases.
Autodesk Forums:
Administrator Productivity
