Installation & Licensing
Autodesk 2011 network license issue
5 REPLIES 5
John_de_Schulthess
943 Views, 5 Replies
I have setup a 2011 64 network deployment that works fine with our shared network licenses.  When I try to do a 32 bit deployment the installation seems to go fine but when trying to run AutoCAD on the workstation it acts as a standalone installation and asks  you to activate.  It then insists that the serial number is not valid.  I also tried to do a deployment for 2010 and encountered the same error for that network serial number also.  It gives the error as "Error 123".
5 REPLIES 5
Seems as though your network deployment is created as a stand-alone install rather than a network install.  You may need to modify or remake your deployment image.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Ok.  That was it.  I had to click on configure when I got to the create deployments page where standalone was the default option.  I don't recall doing that with the 64 bit install ...
Glad you got it up and running.  The 2012 products ask you instead of making you search for it, which is a huge plus.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Autodesk Forums:
OK, thanks.
Now I'm wondering if I used the standalone serial number in the 64 bit deployment I used and that is why it is working fine.  Guess I better check that!
So long as it is a valid serial number and it is configured as a network install, it really shouldn't matter.  It will grab the license from the NLM.  Smiley Wink
Autodesk Forums:
Administrator Productivity
