Installation & Licensing
AutocadActivation 2007 Student Version - Need new code
1 REPLY 1
demondaxelrod
511 Views, 1 Reply
I recently tried to move my Autocad 2007 software from an old computer to my new laptop.  Unfortunately, I found out that this version of Autocad does not support my new operating system on my laptop.  I uninstalled on my laptop and tried to reinstall on my original computer.  I then had a grace period to use the product which has expired.  How do I receive a new activation code and get the program installed back on my original computer?
1 REPLY 1
TravisNave
in reply to: demondaxelrod
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
You will need to provide your serial number and the request code.
Good Luck!
Autodesk Forums:
Administrator Productivity
