I would like to save this drawing down to AutoCAD2009. Can I do that with AutoCAD360 or do I need to use something else?
Solved by DarrenP. Go to Solution.
no i don't think so
but you can use DWG trueview which is free to use
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
DarrenP
Make sure you save it back to 2007 format, as that is what 2009 uses.
