Installation & Licensing
193 Views, 1 Reply
autocad2008 reinstalling
I have Autocad 2008 with the license still active, but we not following the subscription. Now the PC damage and change the mainboard, after install the autocad and using the license https://register.autocad.com , they say inccorect license.
Thanks.
1 REPLY 1
TravisNave
If your license was upgraded under Subscription and lapsed, or if you upreaded or cross-graded this license yourself, then your lease has expired. If you never activated a newer version, Autodesk may be able to provide you with a new request code.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
