Installation & Licensing
Autocad won't install on my computer
12 REPLIES 12
Message 1 of 13
36034 Views, 12 Replies
Hi there
I recently downloaded Autocad and architecture 2013. Before installing, I uninstalled all the previous autocad I had because i wanted to tidy up my computer. However when I try to install, I get error messages saying it failed. Here is the log for it.
2013/10/7:23:35:52 Gazza GAZZA-PC === Setup started on GAZZA-PC by Gazza ===
2013/10/7:23:35:52 Gazza GAZZA-PC Launch
2013/10/7:23:35:54 Gazza GAZZA-PC === Setup ended ===
2013/10/7:23:35:54 Gazza GAZZA-PC PageOpen LaunchDialog
2013/10/7:23:35:58 Gazza GAZZA-PC PageOpen LicenseDialog
2013/10/7:23:36:00 Gazza GAZZA-PC PageOpen ProductInfoDialog
2013/10/7:23:36:03 Gazza GAZZA-PC PageOpen ProductSelectionDialog2
2013/10/7:23:36:04 Gazza GAZZA-PC PageOpen FullProgressDialog
2013/10/7:23:36:04 Gazza GAZZA-PC Installing DirectX Runtime: C:\Gary Wang\Downloads\Design\autocad\3rdParty\DirectX\DXSETUP.exe /silent
2013/10/7:23:36:42 Gazza GAZZA-PC Install DirectX Runtime Succeeded
2013/10/7:23:36:42 Gazza GAZZA-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Gary Wang\Downloads\Design\autocad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/7:23:36:42 Gazza GAZZA-PC Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/10/7:23:36:42 Gazza GAZZA-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/10/7:23:36:45 Gazza GAZZA-PC PageOpen InstallCompleteDialog
2013/10/7:23:37:13 Gazza GAZZA-PC === Setup ended ===
I've had a look through the forums but found nothing and I dont really understand how to read this log.
Please help
12 REPLIES 12
Message 2 of 13
avto
Hi Ganzo,
Thank you for using Autodesk Forums.
A. Download ACAD 2013 installer from virtual agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window, click Downloading and Installation.
5.Click Software Download links.
6.Click "I need to redownload my product."
7.Click "AutCAD Products"
8.Select the appropriate product and click the link to download.
B. Install AutoCAD 2013 as follows:
1.Logon as an Administrator.
2.Empty your TEMP folder.  To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
3.Disable your Antivirus software.
4.Disable UAC.
http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
5.Install AutoCAD 2013.
Please let us know if this helps.
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
Message 3 of 13
in reply to: avto
Thanks heaps!!! The first option worked, I can finally do some work at home now haha.
Message 4 of 13
in reply to: avto
Hello, unfortunately it hasn't helped in my case.
Here is my installation log
2015/5/4:23:19:13 Administrator HOME-PC === Setup started on HOME-PC by Administrator ===
2015/5/4:23:19:13 Administrator HOME-PC Launch
2015/5/4:23:19:24 Administrator HOME-PC PageOpen LaunchDialog
2015/5/4:23:19:52 Administrator HOME-PC === Setup ended ===
2015/5/4:23:20:06 Administrator HOME-PC === Setup started on HOME-PC bby Administrator ===
2015/5/4:23:20:06 Administrator HOME-PC Launch
2015/5/4:23:20:17 Administrator HOME-PC === Setup ended ===
2015/5/4:23:20:07 Administrator HOME-PC === Setup started on HOME-PC by Administrator ===
2015/5/4:23:20:07 Administrator HOME-PC Launch
2015/5/4:23:20:11 Administrator HOME-PC PageOpen LaunchDialog
2015/5/4:23:20:17 Administrator HOME-PC PageOpen LicenseDialog
2015/5/4:23:20:20 Administrator HOME-PC PageOpen ProductInfoDialog
2015/5/4:23:20:26 Administrator HOME-PC PageOpen ProductSelectionDialog2
2015/5/4:23:20:27 Administrator HOME-PC PageOpen FullProgressDialog
2015/5/4:23:20:28 Administrator HOME-PC Installing DirectX Runtime: H:\Install\!Soft\Acad\2013\3rdParty\DirectX\DXSETUP.exe /silent
2015/5/4:23:20:31 Administrator HOME-PC Install DirectX Runtime Succeeded
2015/5/4:23:20:31 Administrator HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="H:\Install\!Soft\Acad\2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/5/4:23:20:31 Administrator HOME-PC Install FaroSDK Failed Failure is ignored, Result=2
2015/5/4:23:20:31 Administrator HOME-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=ru-ru ADSK_SOURCE_ROOT="H:\Install\!Soft\Acad\2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/5/4:23:20:31 Administrator HOME-PC Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2015/5/4:23:20:31 Administrator HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
The line
appears to me quite weird, because there's almost no mentions about all over the Internet.
I'll very appreciated for any help.
Message 5 of 13
ukdxb012
Did you download the software via the Autodesk Virtual Agent or Autodesk Account as Browser Download?
Also when downloading and installing, did you disable your firewall and antivirus and turn off your UAC settings?
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 6 of 13
ukdxb012
Also, try installing from the C:\ drive instead of H:\
Your not trying to install to H are you instead of C?
Duncan Brannan
Twitter | LinkedIn
Message 7 of 13
in reply to: ukdxb012
I'll try to describe my system.
The drive C:\ is SSD , the drive H:\ is a plain HDD.
My antivirus is ESET and always completely disabled for installation.
I'm installing from copy on my HDD
UAC is disabled, the installation is commiting under Administrator.
Kind regards.
Message 8 of 13
ukdxb012
Have you tried installing from where the Autodesk software unpacked originally from C:\?
I would suggest downloading again from Autodesk Virtual Agent, unpacking the software from the exe to C:\Autodesk\ and then running the installation from there, not from your H:\ location.
If it doesn't work, could you upload the log file created from whilst installing from C:\
Duncan Brannan
Twitter | LinkedIn
Message 9 of 13
DuncanBrannan82, yes, it works!
Eventually got the AutoCad installed. Thank you so much! Appreciated.
Message 10 of 13
ukdxb012
Glad everything is now working for you 🙂
Duncan Brannan
Twitter | LinkedIn
Message 11 of 13
I've been trying to download Autocad for 2 days now. I've tried all 3 types of downloads and attempted 6 times already. I've tried 2015-2017 and none work. I've narrowed It down to the material library not being download. Im going crazy already . I'm trying the spirit ion here but step 6 is nowhere to be found. Please. Help.
Message 12 of 13
I have been using autocad without any problems on my laptop for the last several months however yesterday when I went to start the program either by clicking on the program icon or a drawing I had an error (I think the same as below). Over last night and this morning I have jumped through hoops trying to fully uninstall and reinstall Autocad as around 8 times the process got through download and started install before saying that the install of all components had failed . Finally just now I succeeded in installing Autocad 2017 by not choosing the other two tickboxes below however as soon as I launch a very similar problem comes up on screen as before I uninstalled. I don't have the exact record of the previous error but it was similar and not identical (the exception was at a different location at least one time).
Message 13 of 13
try to uninstall all Microsoft Visual C++ programs then try to install...autocad
Administrator Productivity
