Installation & Licensing
AutoCad won't finish installing
1 REPLY 1
Steviebb
777 Views, 1 Reply
The AutoDesk window says that AutoCad had downloaded and installed but to finish, you need to configure it by hitting the 'INSTALL" button but the button won't activate/light up for me to press it. Any ideas of what is happening here?
1 REPLY 1
TravisNave
in reply to: Steviebb
You probably have one of the install options expanded, like if you were doing a custom install.  Once you collapse it back, the install button will light up.  Hope that makes sense.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
