Hello -
I am having trouble installing Autocad 2012 64bit on the Windows partition of my MacbookPro.
I have tried a number of suggested solutions (directX install... etc) but none are working.
It gets about halfway done before throwing this error.
2012/8/14:16:44:03 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2012/8/14:16:44:03 Joseph JOSEPH-PC Launch
2012/8/14:16:44:06 Joseph JOSEPH-PC === Setup ended ===
2012/8/14:16:44:04 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2012/8/14:16:44:04 Joseph JOSEPH-PC Launch
2012/8/14:16:44:07 Joseph JOSEPH-PC PageOpen LaunchDialog
2012/8/14:16:44:16 Joseph JOSEPH-PC You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/8/14:16:44:22 Joseph JOSEPH-PC You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/8/14:16:44:28 Joseph JOSEPH-PC PageOpen BeginDeploymentDialog
2012/8/14:16:44:38 Joseph JOSEPH-PC PageOpen LaunchDialog
2012/8/14:16:44:39 Joseph JOSEPH-PC You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/8/14:16:44:50 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:12:17:01 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:12:17:01 Joseph JOSEPH-PC Launch
2013/2/12:12:17:33 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:12:17:03 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:12:17:03 Joseph JOSEPH-PC Launch
2013/2/12:12:17:23 Joseph JOSEPH-PC PageOpen LaunchDialog
2013/2/12:12:19:12 Joseph JOSEPH-PC You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2013/2/12:12:19:18 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:12:44:08 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:12:44:08 Joseph JOSEPH-PC Launch
2013/2/12:12:46:13 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:12:44:09 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:12:44:09 Joseph JOSEPH-PC Launch
2013/2/12:12:46:14 Joseph JOSEPH-PC PageOpen LaunchDialog
2013/2/12:12:47:01 Joseph JOSEPH-PC PageOpen LicenseDialog
2013/2/12:12:47:05 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2013/2/12:12:47:29 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2013/2/12:12:47:35 Joseph JOSEPH-PC PageOpen FullProgressDialog
2013/2/12:12:47:35 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/12:12:48:29 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2013/2/12:12:48:29 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:12:48:29 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2013/2/12:12:48:29 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:12:50:02 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2013/2/12:12:50:02 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:12:50:27 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:12:50:27 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:12:50:52 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2013/2/12:12:51:05 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AIDF09.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:12:51:21 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/2/12:12:51:40 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2013/2/12:12:51:50 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:12:52:18 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/12:12:52:18 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/12:12:52:19 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2013/2/12:12:53:08 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:13:03:27 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:13:03:27 Joseph JOSEPH-PC Launch
2013/2/12:13:03:40 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:13:03:37 Joseph JOSEPH-PC PageOpen LaunchDialog
2013/2/12:13:04:49 Joseph JOSEPH-PC PageOpen LicenseDialog
2013/2/12:13:07:18 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2013/2/12:13:08:49 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2013/2/12:13:08:51 Joseph JOSEPH-PC PageOpen FullProgressDialog
2013/2/12:13:08:52 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/12:13:09:47 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2013/2/12:13:09:47 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:09:47 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2013/2/12:13:09:47 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:10:33 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2013/2/12:13:10:33 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:10:58 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:13:10:58 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:11:27 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2013/2/12:13:11:46 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AI868E.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:11:55 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/2/12:13:12:05 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2013/2/12:13:12:26 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:13:12:51 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/12:13:12:51 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/12:13:12:52 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2013/2/12:13:12:59 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:13:27:41 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:13:27:41 Joseph JOSEPH-PC Launch
2013/2/12:13:31:44 Joseph JOSEPH-PC === Setup ended ===
2013/2/12:13:27:43 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2013/2/12:13:27:43 Joseph JOSEPH-PC Launch
2013/2/12:13:31:46 Joseph JOSEPH-PC PageOpen LaunchDialog
2013/2/12:13:44:15 Joseph JOSEPH-PC PageOpen LicenseDialog
2013/2/12:13:57:50 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2013/2/12:13:58:12 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2013/2/12:13:58:15 Joseph JOSEPH-PC PageOpen FullProgressDialog
2013/2/12:13:58:15 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/12:13:58:52 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2013/2/12:13:58:52 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:13:58:52 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2013/2/12:13:58:52 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:14:00:11 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2013/2/12:14:00:11 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:14:00:38 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:14:00:38 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:14:00:52 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2013/2/12:14:00:56 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AIBB35.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/12:14:01:21 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/2/12:14:01:42 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2013/2/12:14:01:48 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/12:14:02:04 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/12:14:02:04 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/12:14:02:06 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2013/2/12:14:02:34 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:17:40:17 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/29:17:40:17 Joseph JOSEPH-PC Launch
2014/8/29:17:42:15 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:17:40:18 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/29:17:40:18 Joseph JOSEPH-PC Launch
2014/8/29:17:42:16 Joseph JOSEPH-PC PageOpen LaunchDialog
2014/8/29:17:42:31 Joseph JOSEPH-PC PageOpen LicenseDialog
2014/8/29:17:42:34 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2014/8/29:17:42:55 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2014/8/29:17:43:00 Joseph JOSEPH-PC PageOpen FullProgressDialog
2014/8/29:17:43:00 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/8/29:17:44:10 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2014/8/29:17:44:10 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:17:44:10 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2014/8/29:17:44:10 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:17:45:23 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2014/8/29:17:45:23 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:17:45:52 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:17:45:52 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:17:46:07 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2014/8/29:17:46:09 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AI6289.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:17:46:24 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/8/29:17:46:40 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2014/8/29:17:46:46 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:17:47:18 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2014/8/29:17:47:18 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/8/29:17:47:18 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2014/8/29:17:48:14 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:18:00:20 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/29:18:00:20 Joseph JOSEPH-PC Launch
2014/8/29:18:00:50 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:18:00:45 Joseph JOSEPH-PC PageOpen LaunchDialog
2014/8/29:18:02:18 Joseph JOSEPH-PC PageOpen LicenseDialog
2014/8/29:18:02:26 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2014/8/29:18:02:42 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2014/8/29:18:02:54 Joseph JOSEPH-PC PageOpen FullProgressDialog
2014/8/29:18:02:54 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/8/29:18:03:41 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2014/8/29:18:03:41 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:18:03:41 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2014/8/29:18:03:41 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:18:04:19 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2014/8/29:18:04:19 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:18:04:41 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:18:04:41 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:18:04:59 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2014/8/29:18:05:03 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AIBEEB.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:18:05:17 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/8/29:18:05:20 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2014/8/29:18:05:25 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:18:05:52 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2014/8/29:18:05:52 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/8/29:18:05:52 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2014/8/29:22:25:42 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:23:27:00 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/29:23:27:00 Joseph JOSEPH-PC Launch
2014/8/29:23:27:00 Joseph JOSEPH-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/8/29:23:27:04 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:23:26:55 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/29:23:26:55 Joseph JOSEPH-PC Launch
2014/8/29:23:30:14 Joseph JOSEPH-PC === Setup ended ===
2014/8/29:23:30:17 Joseph JOSEPH-PC PageOpen LaunchDialog
2014/8/29:23:30:31 Joseph JOSEPH-PC PageOpen LicenseDialog
2014/8/29:23:30:35 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2014/8/29:23:31:17 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2014/8/29:23:31:21 Joseph JOSEPH-PC PageOpen FullProgressDialog
2014/8/29:23:31:21 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/8/29:23:31:57 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2014/8/29:23:31:57 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:23:31:57 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2014/8/29:23:31:57 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:23:33:14 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2014/8/29:23:33:14 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:23:33:40 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:23:33:40 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:23:33:51 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2014/8/29:23:33:57 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AI9C1F.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/29:23:34:14 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/8/29:23:34:29 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2014/8/29:23:34:33 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/29:23:34:59 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2014/8/29:23:34:59 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/8/29:23:34:59 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2014/8/29:23:36:52 Joseph JOSEPH-PC [Error: 1056] An instance of the service is already running.
2014/8/29:23:36:52 Joseph JOSEPH-PC === Setup ended ===
2014/8/30:07:22:08 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/30:07:22:08 Joseph JOSEPH-PC Launch
2014/8/30:07:24:20 Joseph JOSEPH-PC === Setup ended ===
2014/8/30:07:24:25 Joseph JOSEPH-PC PageOpen LaunchDialog
2014/8/30:07:24:39 Joseph JOSEPH-PC PageOpen LicenseDialog
2014/8/30:07:24:43 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2014/8/30:07:25:06 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2014/8/30:07:25:08 Joseph JOSEPH-PC PageOpen FullProgressDialog
2014/8/30:07:25:08 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/8/30:07:26:03 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2014/8/30:07:26:03 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:07:26:03 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2014/8/30:07:26:03 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:07:26:59 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2014/8/30:07:26:59 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:07:27:12 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/30:07:27:12 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:07:27:31 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2014/8/30:07:27:36 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AI63C1.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:07:27:51 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/8/30:07:28:00 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2014/8/30:07:28:05 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/30:07:28:24 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2014/8/30:07:28:24 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/8/30:07:28:25 Joseph JOSEPH-PC PageOpen InstallCompleteDialog
2014/8/30:07:28:37 Joseph JOSEPH-PC === Setup ended ===
2014/8/30:15:50:06 Joseph JOSEPH-PC === Setup started on JOSEPH-PC by Joseph ===
2014/8/30:15:50:06 Joseph JOSEPH-PC Launch
2014/8/30:15:52:52 Joseph JOSEPH-PC === Setup ended ===
2014/8/30:15:52:54 Joseph JOSEPH-PC PageOpen LaunchDialog
2014/8/30:15:55:39 Joseph JOSEPH-PC PageOpen LicenseDialog
2014/8/30:15:56:59 Joseph JOSEPH-PC PageOpen ProductInfoDialog
2014/8/30:15:57:23 Joseph JOSEPH-PC PageOpen ProductSelectionDialog2
2014/8/30:15:57:47 Joseph JOSEPH-PC PageOpen FullProgressDialog
2014/8/30:15:57:47 Joseph JOSEPH-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/8/30:15:58:58 Joseph JOSEPH-PC Install DirectX Runtime Succeeded
2014/8/30:15:58:58 Joseph JOSEPH-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:15:58:58 Joseph JOSEPH-PC Install FaroSDK Failed Failure is ignored, Result=1622
2014/8/30:15:58:58 Joseph JOSEPH-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:15:59:57 Joseph JOSEPH-PC Install Autodesk Material Library 2012 Succeeded
2014/8/30:15:59:57 Joseph JOSEPH-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:16:00:11 Joseph JOSEPH-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/30:16:00:11 Joseph JOSEPH-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:16:00:31 Joseph JOSEPH-PC Install Autodesk Content Service Succeeded
2014/8/30:16:00:34 Joseph JOSEPH-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Joseph\AppData\Local\Temp\_AI7603.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/30:16:00:49 Joseph JOSEPH-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/8/30:16:00:58 Joseph JOSEPH-PC Rollback Autodesk Content Service Succeeded
2014/8/30:16:01:03 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/8/30:16:01:25 Joseph JOSEPH-PC Rollback Autodesk Material Library 2012 Succeeded
2014/8/30:16:01:25 Joseph JOSEPH-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Any help would be much appreciated.
The error shows that you need to donwload 64 bit setup for AutoCAD 2012 & install the one.
Currently you are trying to install 64bit on 32 bit machine or vice versa.
