Installation & Licensing
AutoCad Student Archi 2010 installation failure
2 REPLIES 2
323 Views, 2 Replies
I've downloaded your AutoCad application for students yet it failed while installing. Please help me and see the attached picture
2 REPLIES 2
arlinpega.bibat
Hi sowhatifitsjecs:
You may paste the installation log file here so that our Product Support Team may be able to assist you further with your issue.
Arlin Bibat
2012/1/8:11:21:06 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/8:11:21:13 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/8:11:21:17 jhun navarro JONAVARROPC === Setup ended ===
2012/1/8:11:44:24 jhun navarro JONAVARROPC Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=193
2012/1/8:11:44:36 jhun navarro JONAVARROPC === Setup ended ===
2012/1/8:11:44:54 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/8:11:45:01 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/8:11:45:03 jhun navarro JONAVARROPC === Setup ended ===
2012/1/8:11:47:56 jhun navarro JONAVARROPC Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=193
2012/1/8:11:49:56 jhun navarro JONAVARROPC Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=193
2012/1/8:12:22:13 jhun navarro JONAVARROPC === Setup ended ===
2012/1/9:10:13:38 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/9:10:13:49 jhun navarro JONAVARROPC === Setup started on JONAVARROPC by jhun navarro ===
2012/1/9:10:13:53 jhun navarro JONAVARROPC === Setup ended ===
2012/1/9:10:19:18 jhun navarro JONAVARROPC Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=193
Administrator Productivity
