"reenienal" a écrit dans le message de groupe de discussion :Sometimes
href="mailto:6082735@discussion.autodesk.com">6082735@discussion.autodesk.com...
when trying to open a drawing that someone else already has open, Autocad asks
if you want to open it "read only" and the user clicks on "yes". Then an error
message pops up saying "Sharing violation error" and the user gets the browser
again. Have you seen this problem before? Another problem is sometimes
xreferences will not show up in a drawing. When you go to the Xref Manager,
the status reads "Not Found". The xref IS in the path that is in the Xref
Manager. This is verified using Windows Explorer. It won't let you repath to
the drawing or reload it. I suspect that this problem is related to the
problem above. This problem seems to have occurred only after swtching from a
Novell server to a Windows 2003 server with VMware. The problem is not easy to
solve because it is not specific to any one person, project, drawing file,
drawing history, office location, or Autocad version. Does anyone have a
possible solution to this problem?
"reenienal" a écrit dans le message de groupe de discussion :Hi.
title="mailto:6083854@discussion.autodesk.com CTRL + Cliquez ici pour suivre le lien"
href="ma......
We are using Autocad 2006 on Windows XP Professional SP3. Each office has
Riverbed steelheads. We had no problems with the steelheads while running
Novell. We are looking at the steelheads in combination with the Windows
server to see if the problem lies somewhere with
them.
title="mailto:6085550@discussion.autodesk.com CTRL + Cliquez ici pour suivre le lien"
href="ma......
Frank. Thanks for the information. I knew that there were reports with 2007. I
wish this was our problem, but it is not. We are continuing to look at the
steelheads and the windows server. Reenie
title="mailto:6085974@discussion.autodesk.com CTRL + Cliquez ici pour suivre le lien"
href="ma......
I mention VMware because the we are using VMware Executive with the Windows
2003 server. When we moved everything from the Novell server to the Windows
server and began to use VMware is when the problems started. Two major changes
happened at the same time; the Windows server and the VMware. The virtual
server is 4 TB. It is broken down into one 2 TB drive and the rest are
numerous smaller drives that equal 2 TB. Reenie Edited by: reenienal on Dec 8,
2008 4:37 PM
