The sample script in the AutoCAD Raster Design 2011 Network Administrators Guide (ard_nag.chm) contains a few typos. This sample script contains corrections for them.
This sample script silently installs the program in a typical configuration. You can use this sample script by substituting your own information for these lines (required):
strADSKFirstName = "My First Name"
strADSKLastName = "My Last Name"
strADSKOrganization = "My Organization"
strADSKSNPrefix = "123"
strADSKSNNumber = "12345678"
strADSKProdKey= "ABCDE"
If you are installing with a network license:
1. specify your license server hostname here:
strADSKServerPath = "myFlexNetServer"
2. Rem this line with an apostrophe:
RunStandaloneInstall()
EX: 'RunStandaloneInstall()
3. Un-rem this line:
'RunSingleLicenseServerInstall()
EX: RunSingleLicenseServerInstall()
Remove the .txt extension from the file name after you have downloaded it.
