Installation & Licensing
New Member
0 Kudos
Post 1 of 4
AutoCAD not installing
376 Views, 3 Replies
01-30-2013 02:50 PM
I tried to download the student version of AutoCAD 2013.  When I got to the installation wizard I entered the serial # and product code for AutoCAD.  The wizard shows a green check-mark for Autodesk Inventor Fusion 2013 installed, but AutoCAD shows a circle/slash and will not allow me to check the box (see attached MS WORD file).  When I hover it says AutoCAD 2013 English is installed but there is no desktop shortcut and the files are not there, and I can't find the AutoCAD application.  I did NOT enter the Autodesk Inventor product key!
Where did AutoCAD go?
282 Kudos
Post 2 of 4
Re: AutoCAD not installing
01-30-2013 04:48 PM in reply to: showneck
Hello Robert,
Have you checked / can you attach your installation log so that we can see exactly where it's failing?
Philip Schmelzer
New Member
0 Kudos
Post 3 of 4
02-01-2013 01:49 PM in reply to: showneck
I am having the exact same problem!!! I have even taken my computer to two different professionals and they were unable to figure out the problem. It is so frustrating..
282 Kudos
Post 4 of 4
02-04-2013 12:01 PM in reply to: bailey-krstic
Hi Bailey,
Did you look through your installation log as well?
Philip Schmelzer
