Installation & Licensing
484 Views, 3 Replies
autocad mep 2014
I installed Autocad MEP 2014, it did not work, I uninstalled (multiple times) and it is gone from my control panel programs , and now when ever I try to reinstall it says 'already installed', and yet it does not show up on my windows registry or control panel programs ????? Autodesk ITT suggested I uninstall and REinstall every autodesk program that I have....which is ludicrious...I have multiple versions, my whole computer is filled with autodesk programs,  and I do not want to lose the current one which my projects are in and is working, version Autocad MEP 2012.
Anyone out there with a better solution?
3 REPLIES 3
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you. I ran the microsoft uninstaller and got rid of MEP 2014 but then when I ran the installation again I got a:
rollback directX runtime failed failure is ignored, result= 1619 and the installation aborted result=1603.
I don't think I should have to be an IT to install a program ????
TravisNave
Hard telling, I have never *not* been IT.
Post your log file, it might shed some light.
Autodesk Forums:
Administrator Productivity
