Installation & Licensing
AutoCAD MEP 2011 will not run
5 REPLIES 5
Luther-LLKCAD
597 Views, 5 Replies
I installed AutoCAD MEP 2011.I then re-started my computer. If I try to run AutoCAD MEP 2011 I get the opening page and then the screen turns gray and closes out of AutoCAD. It goes back to my computer screen. It will not run. Why? I installed and uninstalled this program 3 TIMES and it still will not work. From the global business services I received 3 e- mails with 3 different activation file text. All on the same day and time all before I uninstalled for the frist time.
5 REPLIES 5
steve
in reply to: Luther-LLKCAD
same problem here too.
xincao
Hi Luther and Steve
Can I know the configuration of your computer hardware?
Justin
Product Designer of AutoCAD MEP
steve
in reply to: xincao
XP Pro
version 2002
serv pack 3
intel core 2 duo cpu
t9550 @ 2.66 GHz
2.66 Ghz. 3.48 GB ram
ATI FirePro M7740
It has been working fine for months and it just started doing this.  I use two stand alone computers, so I have to transfer the license back and forth with the LTU and it always works fine until now.  I haven't loaded any new software either.
Thanks in advance
Pamenina
Hi!!! I have the same problem.... I need to fix it as soon as I can... has somebody solved it???
Pamenina
in reply to: xincao
Hi....I'm having the same problem about running autocad mep 2011: I installed it, then re-started my computer. If I try to run AutoCAD MEP 2011 I get the opening page and then the screen turns gray and closes out of AutoCAD..... I have a notebook with WINDOWS 7 HOME PREMIUM, 6 GB (RAM), 64 bits, Intel(R) Core(TM) i7.... how can I solve it?
Administrator Productivity
