Installation & Licensing
Autocad Mechanical 2015 thinks it is already installed
2 REPLIES 2
274 Views, 2 Replies
Hu,
I have used Windows uninstall of all the Autodesk pproducts on this machine.
I have gone to Programs86 (etc)->Autodesk and deleted
Same with c:\Autodesk
and same with the two users in the App Data (Windows 7 machine) both local and roaming
deleted all mentions of AutoDesk from the registry
I once again after many times download from:
http://www.autodesk.com.au/products/autocad-mechanical/free-trial#
I have a key. I go through normall installation and then it comes up with a Red Circle next to AutoCad Mechanical 2015. You move the mouse over this circle and it says the product is already installed. It says if I want to install language packs etc click here and opens a folder. But there is no Autocad Mechanical installed and so all fails.
Any ideas?
2 REPLIES 2
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
