Installation & Licensing
AutoCAD® Mechanical 2014 Language Pack Failed Installation aborted, Result=1603
1 REPLY 1
1537 Views, 1 Reply
In case someone else searches for a solution to this problem.
Trying to install Autodesk Product Design Suite Standard from Distribution point via DFS share.  Was getting this error message:
Install	AutoCAD® Mechanical 2014 Language Pack	Failed	Installation aborted, Result=1603
Rollback	Autodesk® AutoCAD® Mechanical 2014	Succeeded
Rollback	Autodesk Content Service Language Pack	Succeeded
Rollback	Autodesk Content Service	Succeeded
Rollback	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1619
Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
Rollback	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Installation aborted, Result=1619
Rollback	Microsoft Visual C++ 2010 SP1 Redistributable (x64)	Failed	Installation aborted, Result=1619
Rollback	Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)	Failed	Installation aborted, Result=1619
Rollback	Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)	Failed	Installation aborted, Result=1619
Rollback	.NET Framework Runtime 4.5	Failed	Failure is ignored, Result=1619
=== Setup ended ===
 Then it would roll back the AutoCAD Mechanical and would then complete with AutoCAD Mechanical not being installed.
Was able to get around this by adding IGNORE_FAILURE=YES to [ACM_LANGPACK] section in the config ini.   (Which I found in the forums.)
Turned off the silent install.  And got this message (See attached)  Error 1308: Source file not found: main.css.bak
What happened is the default settings for DFS does not copy .bak files.  So this stupid bak file was making the entire thing fail out on the other DFS shares.  http://technet.microsoft.com/en-us/library/cc753409.aspx
Hopefully anyone searching for this specific error will find it here.
Tags (1)
1 REPLY 1
TravisNave
Excellent find.  Always good to see more fixes on 1603 errors.
Thanks for sharing!
Autodesk Forums:
Administrator Productivity
