Good Morning,
I have a user that when opening AutoCAD Mechanical 2011 gets the message "No Access to server". Is this because there are no licenses available or it cannot see the server itself? Any suggestions and I am new at the AutoCAD Network Licensing stuff so gorgive a newbie questions.
Andrew
can't say need more info
can you post a screen shot?
DarrenP
I used LMTOOLS Utility to check the licenses and I pasted some of the info I could onto a Notepad to see if it makes sense or if you can see any issues there as well. Do we have enough licenses for AutoCAD Mechanical 2011?
Andrew
you only have 2 licenses of Inventor 2011 and one is being borrowed and the other is being used
so if a 3rd person is trying to access mechanical they will get the message you posted
DarrenP
We actually freed up a license and the user is still getting the message so our next step is to reinstall Mechanical 2011 since we can have the user open up Mechanical 2011 on a virtual machine. Let me know other options if you have seen this beefore. Thanks for all of your help. Much appreciated.
Andrew
