Installation & Licensing
AutoCAD Map 3D 2013 installation indicates Map 3D already installed
1 REPLY 1
637 Views, 1 Reply
Initial installation of AutoCAD Map 3D 2013 failed on .NET 4 and DirectX components on Windows XP 32-bit system.
However, Control Panel|Add/Remove Programs showed product installed.
Installed .NET 4 and DirectX manually via Microsoft downloads. Did the Chang/Remove thing in Control panel to Repair installation.  Repair installation failed.
Uninstalled  AutoCAD Map 3D 2013via Control Panel.
Followed instructions in attached document titled "How to remove Autodesk products from a Windows system". Rebooted system and restarted installation via setup.exe. Entered license key and product code and designated server license manager.
Still, the install screen indicates that AutoCAD Map 3D 2013 is already installed.
Can anyone help?
Thanks in advance for any help or even clues!
1 REPLY 1
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
