Created MAP 3D 2011 package for deployment.
Job fails: Log file reports Install AutoCAD Map 3D 2011 Language Pack Failed Installation aborted, Result=1603
Install process then performs roll back and uninstalls all elements of deployments.
Client PC Event Viewer Message:
Error reading from file: \\ source path ...\x86\en-us\acad\Program Files\Root\HelpHtml\3dsolid-cone_help.swf. System error 3. Verify that the file exists and that you can access it.
This file path does not exists and only SWF (shockwave files?) included are in ...Program Files\Root\Support\WelcomeScreen
Could create file path and file but is there a better solution?
Any ideas?
Thanks in advance
Solved by access_it. Go to Solution.
I have located file on install DVD. Have copied D:\x86\en-us\acad\acad\program files\root\helphtml to within the AdminImage.
Deployment has ran successfully. Would have expected these files to have been incorporated in original deployment job that was generated
