What is the exact error message(s) encountered at the workstation. Also
check the log file and see if the startup attempts are registering. If they
are you are likely to see why the license was denied. If you do not see a
hit from the failed attempts you are not getting to the server at all. In
the later case, name resolution problems or blocked ports are often the
problem. Make sure that ping echoes the expected IP address.
Jerry Milana,
Autodesk Professional Services
"Rich John" wrote in message
news:AD0D0EF0B5F3EC0E2AF00F23B3A9C736@in.WebX.maYIadrTaRb...
> thanks, I'll look at that one.
> it does not explain why I can't run it when the server and client are on
tte
> same machine which is a windows NT4 workstation.
> rich
> "Andi Auburger" wrote in message
> news:460763C95C8A2C9EE1FC38BF05E9485A@in.WebX.maYIadrTaRb...
> > Rich John schrieb:
> > > Anyone have any ideas for me?
> > Hi Rich,
> > just a guess:
> > Have you checked the time/date on the clients, too?
> > All times and dates in your network have to be the same.
> > One of our costumers have success with the new "adesksys.dll". Search
> > the knowledgebase for "DL154103"
> > Regards
> > Andi
