You will need a different code, as each computer has a unique identifier,
but you should be able to do it through the web if it's not been done too
many times already. Worst case, call them at 800.551.1490.
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:5197587@discussion.autodesk.com...
I have 1 stand-alone license for LT 2006. According to the website , as in
the past, autodesk allows autocad to be installed on 1 laptop that will not
be used at the same time as the computer with the main license. That is
what I want to do. I tried using the original activation code on the
laptop, but that does not work. Do I have to re-activate on the website,
and will it even let me do this without calling autodesk?
