Purchased a subscription for AutoCAD LT 2015 and have tried the three delivery methods to no avail.
For the 'Install Now' - I download the required file, start it and it disappears.
For the 'Download Now' - I get a connection error
For the 'Browser Download' - I downloaded the 1 GB+ file, opened it and it tells me it is for a 32 bit installation and cannot be opened.
Using Window 8
Any help is appreciated. Thank you.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Get the 64-bit version of AutoCAD LT 2015. Good Luck!
