Installation & Licensing
Autocad LT 2014 uninstall and reinstall on new computer.
10 REPLIES 10
Message 1 of 11
niall.shanahan
3900 Views, 10 Replies
I want to uninstall Autocad LT 2014 from a DT and reinstall it on a new DT. What do I have to do? Is it enough to uninstall using the Windows control panel, or are ther extra steps? how do I ensure that the licence is tied to the new DT?
10 REPLIES 10
Message 2 of 11
Hello niall.shanahan!
Welcome to the forums!
To make sure the license is tied to the new desktop, you will need to use the License Transfer Utility to move the license from the old computer to the new one before uninstalling it. The instructions for the License Transfer Utility (LTU) can be found here.
Let me know if this helps.
Patricia Cuizon
Message 3 of 11
Thanks Patricia.
So, basically export the licence via the instructions you provided, install the software to the new computer from disc and finish the process by importing the licence to the new DT. Sounds simple.
Message 4 of 11
You're welcome, niall.shanahan.
Yes, that's all you have to do. Good luck!
Patricia Cuizon
Message 5 of 11
jon
in reply to: niall.shanahan
Can I use this technique to use LT 2014 on my desktop and my laptop, ie use LTU to switch between the two, or is it limited in the number of uses?
Jon
Message 6 of 11
philip.s
in reply to: jon
Hi Jon!
Correct that there is not a limit on LTU uses, however, I also would like to point out that  most license types (excluding educational) allow the software to be installed and activated on 2 separate machines, as long as you are the sole user and the 2 aren't used concurrently. Check out the the Autodesk Product Activation FAQ for more info.
Message 7 of 11
jon
Many thanks for that.  It was very helpful and very prompt
Jon
Message 8 of 11
philip.s
in reply to: jon
Our pleasure!
Message 9 of 11
Hi
I'm trying to transfer an Autocad LT licence but I get the error shown in the attached image.
It says the serial number I entered is invalid, but I didn't enter it - I assume it's picked it up from the registry. It didn't ask me to sign in and until making this post I didn't have an autodesk ID. The S/N and key match those on the box are correct. Can anyone help?!
Toby
Message 10 of 11
camilo.lemos
Hi @Anonymous ,
Our License Assistance team will be happy to help you with this! Please, click on this link and follow the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
Camilo Lemos
Message 11 of 11
in reply to: camilo.lemos
I want to move the Autocad 2007 LT licensed to another desktop(upgrade) but I don't have the media disc anymore.All that I have is that older software installed here with its licensed key. I need an installation kit in order to do it. Where I can download it. And, after the succesfuly installed, is enough to follow the steps indicated in the first post?
Thank You
Administrator Productivity
