Installation & Licensing
AutoCAD LT 2014 - Network Install
2 REPLIES 2
316 Views, 2 Replies
Does AutoCAD LT 2014 support a Network Install so the executable files run over a network without it actually being installed on a client computer?
2 REPLIES 2
DarrenP
you can create a deployment to a server
autocad lt needs to be installed on a workstation
DarrenP
TravisNave
Darren is exactly right.  And since there is no network licensing available for AutoCAD LT, then there is no Citrix solution for this product either.  You would have to upgrade to a full AutoCAD and network activate to get anywhere close to what you are asking.
Here is what is supported:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
