Helllo All,
My company purchased AutoCad LT 2013 and I have installed and uninstalled mutiple times on the same machine as well as a different machine. The issue I am running into is when trying to open the icon on my desktop Autocad opens and than right when it is about to display the ribbon it flashes and closes. The process stays open for about 10-15 more seconds and than closes.
I have gone through the help install/uninstall from this site no luck. I have tried a new computer, no luck. I have tried a new graphics card, no luck.
I am trying to install on a Optiplex 7010mt with 4gb of memory running 64bit windows 7.
Any help would be nice. I would of called support but they seem to be non-existant.
This is very likely a corrupt license issue. You can try deleting the license first and see if it will reactivate:
Delete:
%programdata%\flexnet\adsk*.data
If that doesn't work, you may need to delete the CascadeInfo.cas and ProductInformation.pit file, then reinstall LT.
