Installation & Licensing
AutoCAD LT 2013 PASSIVE install
1 REPLY 1
9035 Views, 1 Reply
Ive been creating deployments for AutoCAD 2013 LT to be deployed through SCCM. i want the installation to be Passive not Silent so that users acn see that there is an installation being completed. I am currently using the below command line.
AdminImage\setup.exe /W /qb /I AdminImage\SEC_X86.ini
When using the above command the progress bar is displayed but it still has the cancel option on the installations.
I have modified the .ini file but so that all MSI installations contain the "/passive" switch but the installation does not get past "initialising"
I have tried modifying the primary msi as below which has made the initial "initialising" window passive but nothing after
PRIMARY_MSI=%platform%\acadlt\acadlt.msi /passive
Any ideas for making the whole installation passive would be appreciated.
Below is my complete .ini files contents.
[SETUP]
PLATFORM=x86
SETUP_CODE={D54FD115-F651-4237-B57C-E4230340EAB6}
TITLE=AcSetupRes.dll;2
LOG=%tmp%\AutoCAD LT 2013 Setup.log
EVALMSI=SetupRes\eval.msi
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_ADD_LP
DEFAULTMEDIALANGUAGE=en-us
DOCUMENT_LINK=http://www.autodesk.com/autocadlt-win-install-help-2013-%setupuilang%
DOCUMENT_FALLBACK_LINK=Docs\acadlt_install_help\index.html
SYSTEMREQUIRE_LINK=http://www.autodesk.com/autocadlt-win-sys-reqs-2013-%setupuilang%
SYSTEMREQUIRE_FALLBACK_LINK=Docs\acadlt_sysreq\index.html
SUPPORT_LINK=http://www.autodesk.com/autocadlt-win-readme-2013-%setupuilang%
SUPPORT_FALLBACK_LINK=Readme\readme.html
#==================== Platform Requirement
OSMAJVER=5
OSMINVER=1
SPMAJVER=2
#==================== Install Execute & UI Sequence
EXE_SEQUENCE=ACADLT;ADR2013
INSTALL_SEQUENCE=ADR2013;ACADLT
UI_SEQUENCE=BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;ACADLT;ADR2013;CADM;SNAP;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg
#==================== UI
UI_MODE=FULLUI
#==================== Deployment Info
DEPLOYMENT_NAME=SEC_X86
CLIENT_LOGGING=YES
EXTRA_FILES=acad;*.exe:Setup:CER:eula:msi:nlsdl:3rdParty\NET\4\wcu\dotNetFramework:setupres:%lang%
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=Setup\AutoCADLTConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2013.0.0.F
ADLM_TRIAL_DAYS=30
#==================== Install Info
INSTALL_PATH=C:\Program Files\Autodesk\
CREATE_DESKTOP_SHORTCUT=YES
#==================== Global MSI Properties
ADMIN_IMAGE_LOCATION=\\secvasutl05\D$\Unpackaged\Autodesk\AutoCAD2013lt_x86\
DEPLOYMENT_PLATFORM=x86
DEPLOYMENT_MODE=MINIMAL
NETWORK_LOG_PATH=\\secvasutl05\D$\Unpackaged\Autodesk\AutoCAD2013lt_x86\Log\
NETWORK_LOGGING=YES
SETUP_LANGUAGES=en-us
[GLOBAL_MSI_PROPERTIES]
#==================== ACADLT
[ACADLT]
PLATFORM=NATIVE
PREREQUISITE=SSE2;DOTNET20;DOTNET4;DOTNET4LANG;DOTNET4KB2468871;VCREDIST2008SP1X86;VCREDIST2010SP1X86;DIRECTX;MSXML6;CM2013;CMILB2013;SNAP_PRE
POSTREQUISITE=ACADLT_PSPACK;ADSYNC
PRODUCT_NAME=AutoCAD LT® 2013
PRODUCT_MESSAGE=AcSetupRes.dll;42
PRODUCT_INSTALLED_INFO_MSG=AcSetupRes.dll;70
PRODUCT_INSTALLED_INFO_URL=AcSetupRes.dll;73
EULA_PATH=eula
LOG=%tmp%\AutoCAD LT 2013 Install.log
EXE_PATH=%platform%\acadlt\acadlt.msi
EXE_PARAM=
ACTION=INSTALL
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
USE_MEDIA=YES
UI_SEQUENCE=InstallTypePage;WorkstationSettingPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage
MAINTENANCE_UI_SEQUENCE=OemPreinstallLicenseDlg;OemPreinstallProductInfoDlg;MaintenanceDlg;AddRemoveFeaturesDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
SUMMARY_FUNC=LoadSummary_LT
SUMMARY_SOURCE=SetupAcadUi.dll
README_FILE=help\contexthelp\readme.htm;AcSetupRes.dll;5
LAUNCH_EXE=acadlt.exe
ADMIN_INSTALL=YES
EXTRA_FILES=acadlt;acadlt\*.ico
DEPLOYMENTLANGUAGE=
CANSPAN=1
LPMODE=MUI
AVAILABLELANGUAGES=en-us
DEFAULTMEDIALANGUAGE=en-US
#==================== ACAD LT Language Pack
EULA_INDEX=-1
EULA_STATE=YES
CONFIG_TRANSFORM=acadlt-SEC_X86.mst
STOCK_TRANSFORMS=
TRANSFORMS=
PATCHES=
[ACADLT_LANGPACK]
PRODUCT_NAME=AutoCAD LT® 2013 Language Pack
EXE_PATH=%platform%\%lang%\acadlt\AcadLTLP.msi
EXE64_PATH=%platform%\%lang%\acadlt\AcadLTLP.msi
ADMIN_INSTALL=YES
LOG=%tmp%\ACAD LT LangPack Install.log
[ACADLT_en-US]
DISK_PROMPT=AcSetupRes.dll;17
DISK_LABEL=acadlt2013
#==================== ACAD LT Product Specific Pack
PATCHES=
[ACADLT_PSPACK]
PLATFORM=NATIVE
PRODUCT_NAME=AutoCAD LT® 2013 Product Specific Pack
EXE_PATH=%platform%\%lang%\acadlt\AcadLTPS.msi
EXE_PARAM=INSTALLSHORTCUTS=0
ADMIN_INSTALL=YES
LOG=%tmp%\ACAD LT PSPack Install.log
LPMODE=MLD_ADR
#================================================= Autodesk tools ============================================================
PATCHES=
[NLM]
PLATFORM=NATIVE
PRODUCT_NAME=Network License Manager
PRODUCT_MESSAGE=AcSetupRes.dll;47
LOG=%tmp%\NLM Install.log
EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi
EXE_PARAM=ALLUSERS=1
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
DISKCOST=8000000
#== Add more available languages
LPMODE=MLD_ADR
AVAILABLELANGUAGES=en-US
[CADM]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk CAD Manager Tools
PRODUCT_MESSAGE=AcSetupRes.dll;46
PREREQUISITE=SSE2;VCREDIST2010SP1X86;VCREDIST2010SP1X64
LOG=%tmp%\CADManager Install.log
EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
LPMODE=MLD_ADR
#==================== ContentService
[SNAP]
PRODUCT_NAME=Autodesk Content Service
PRODUCT_MESSAGE=ContentServiceRes.dll;417
EXE_PATH=%platform%\Tools\snap\ContentService.msi
EXE_PARAM=INSTALLMODE=PUBLIC AUTOSTART=1
LOG=%tmp%\Autodesk Content Service.log
UI_SEQUENCE=Snap_InstallModePage
INSTALL_TYPE=4
IGNORE_FAILURE=YES
DISKCOST=37000000
PREREQUISITE=VCREDIST2008SP1X86;VCREDIST2010SP1X86;DOTNET4;DOTNET4KB2468871
VC_FUNC=ACSCheck_StandAlone
VC_SOURCE=Setup\ContentServiceUI.dll
LPMODE=MLD_INV
#==================== ContentService Language Pack Postrequisite
[SNAP_LANGPACK]
PRODUCT_NAME=Autodesk Content Service Language Pack
EXE_PATH=%platform%\%lang%\Tools\snap\ContentServiceLP.msi
[SNAP_en-US]
[SNAP_PRE]
EXE_PARAM=INSTALLMODE=PRIVATE AUTOSTART=0
ACTION=INSTALL
IGNORE_FAILURE=YES
DISKCOST=37000000
VC_FUNC=ACSCheck_Inline
LPMODE=MLD_INV
PATCHES=
[SNAP_PRE_LANGPACK]
[SNAP_PRE_en-US]
#================================================= Common Autodesk Content ============================================================
PATCHES=
[CM2013]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2013
EXE_PATH=Content\ADSKMaterials\2013\CM\MaterialLibrary2013.msi
LOG=%tmp%\MaterialLibrary2013CM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2013\CM\*.cab
ADMIN_INSTALL=NO
DISKCOST=88000000
ACTION=INSTALL
EXE_PARAM=
PATCHES=
[CMILB2013]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2013 - Low Resolution
EXE_PATH=Content\ADSKMaterials\2013\ILB\BaseImageLibrary2013.msi
LOG=%tmp%\MaterialLibrary2013CMILB.log
EXTRA_FILES=acad;Content\ADSKMaterials\2013\ILB\*.cab
ADMIN_INSTALL=NO
DISKCOST=81000000
ACTION=INSTALL
#================================================= Common Autodesk Components ============================================================
EXE_PARAM=
PATCHES=
[ADR2013]
PLATFORM=ALL
PRODUCT_NAME=Autodesk® Design Review 2013
PRODUCT_ICON=DesignReview.ico
PREREQUISITE=VCREDIST2010SP1X86;DOTNET4;DOTNET4KB2468871
EXE_PATH=x86\%lang%\Components\adr2013\SetupDesignReview2013.msi
EXTRA_FILES=acad;x86\%lang%\Components\adr2013\*.ico
EULA_PATH=eula
PRODUCT_MESSAGE=ADRInstRes.dll;107
LOG=%temp%\ADRInstall2013.log
IGNORE_FAILURE=YES
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;AddRemoveFeaturesDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
ALLOW_ADD_REMOVE=NO
LPMODE=MLD_ADR
POSTREQUISITE=
EXE_PARAM=
EULA_INDEX=-1
EULA_STATE=YES
ACTION=INSTALL
CONFIG_TRANSFORM=SetupDesignReview2013-SEC_X86.mst
STOCK_TRANSFORMS=
TRANSFORMS=
PATCHES=
[ADSYNC]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk Cloud sync
LOG=%tmp%\CloudsyncInstall.log
EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi
EXE_PARAM=ADLANGUAGE=%selectedlang%
ACTION=INSTALL
IGNORE_FAILURE=YES
#================================================= 3rd Party Components ============================================================
PATCHES=
[IE]
PRODUCT_NAME=Internet Explorer 6
PRODUCT_MESSAGE=SetupRes.dll;209
VC_FUNC=IeVerCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=6.0.2800;6.0;1
VC_DESCRIPTION=Detecting Internet Explorer 6
ACTION=INSTALL
EXE_PATH=NULL
EXE_PARAM=
[MSI]
PLATFORM=ALL
PRODUCT_NAME=Windows Installer Redistributable
EXE_PATH=msi
EXE_PARAM=/quiet /norestart
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI
[NLSDL]
PLATFORM=NATIVE
PRODUCT_NAME=Microsoft NLS Downlevel APIs
EXE_PATH=NLSDL\nlsdl.x86.exe
EXE64_PATH=NLSDL\nlsdl.amd64.exe
IGNORE_FAILURE=YES
[MSXML6]
PLATFORM=NATIVE
PRODUCT_NAME=MSXML 6
EXE_PATH=3rdParty\x86\msxml6\msxml6.msi
EXE64_PATH=3rdParty\x64\msxml6\msxml6_x64.msi
VC_FUNC=MsxmlVerCheck
VC_PARAM=6.0
IGNORE_FAILURE=YES
#============= VCREDIST Begin ===============
EXE_PARAM=
PATCHES=
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart /l %temp%\vcredist_x86_2010.log
VC_FUNC=VCx86RedisCheck
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
IGNORE_ERROR=5100
PATCHES=
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
EXE_PARAM=/q /norestart /l %temp%\vcredist_x64_2010.log
VC_FUNC=VCx64RedisCheck
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
IGNORE_ERROR=5100
[VCREDIST2008SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
ROLLBACKABLE=NO
PATCHES=
[VCREDIST2008SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
ROLLBACKABLE=NO
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" "
VC_PARAM={837b34e3-7c30-493c-8f6a-2b0f04e2912c}
[VCREDIST2005SP1ATLX64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" "
VC_PARAM={6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}
[VCREDIST2005X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005\vcredist_x86.exe
VC_PARAM={7299052B-02A4-4627-81F2-1818DA5D550D}
[VCREDIST2005X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005\vcredist_x64.exe
VC_PARAM={071C9B48-7C32-4621-A0AC-3F809523288F}
#============= VCREDIST End ===============
[SSE2]
PRODUCT_NAME=SSE2 Support Check
PRODUCT_MESSAGE=SSE2 Support Check
EXE_PATH=NULL
VC_FUNC=CheckForSSE2Support
VC_SOURCE=Setup\AcSetup.dll
VC_DESCRIPTION=SSE2 Support Check
#============= DOTNET Begin ===============
EXE_PARAM=
[DOTNET4KB2468871]
PLATFORM=NATIVE
PREREQUISITE=DOTNET4
PRODUCT_NAME=.NET Framework Runtime 4.0 KB2468871
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe
EXE64_PATH=3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4 KB2468871
VC_DESCRIPTION=Detecting .NET Framework Runtime 4.0 KB2468871
DISKCOST=760982064
PATCHES=
[DOTNET4]
PLATFORM=ALL
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe
EXE_PARAM=/q
VC_PARAM=.NET Framework 4 Full
VC_DESCRIPTION=Detecting .NET 4.0 Runtime
DISKCOST=352037424
PATCHES=
[DOTNET4LANG]
PRODUCT_NAME=.NET Framework Runtime 4.0 Language Pack
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_%lang%.exe
EXE_PARAM=/q
EXE_LANGS=1036;1040;1031;1034;1046;1041;1042;2052;1028;1029;1038;1045;1049
DISKCOST=3000000
VC_FUNC=DotnetLangPacksVerCheck
VC_PARAM=%lang%;4.0.30319
[DOTNET20]
PLATFORM=NATIVE
PRODUCT_NAME=.NET Framework Runtime 2.0
EXE_PATH=3rdParty\%platform%\NET\2\NetFx20.exe
EXE_PARAM=/q:a /c:"install.exe /q"
VC_PARAM=.NET Framework 2.0
VC_DESCRIPTION=Detecting .NET 2.0 Runtime
DISKCOST=80000000
IGNORE_FAILURE=YES
PATCHES=
[DOTNET]
PLATFORM=ALL
VC_PARAM=4.0.30319
#============= DOTNET End ===============
[DIRECTX]
PLATFORM=ALL
PRODUCT_NAME=DirectX Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
PATCHES=
[FaroSDK]
PLATFORM=ALL
PRODUCT_NAME=FaroSDK
EXE_PATH=3rdParty\FaroSDK\faro_ls.msi
LOG=%tmp%\FaroSDK.log
ACTION=INSTALL
IGNORE_FAILURE=YES
[WMF95X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Windows Media Format 9.5 Series Runtime
EXE64_PATH=3rdParty\x64\wmf\95\wmfdist64.exe
EXE_PARAM=/quiet
IGNORE_FAILURE=YES
VC_FUNC=WMFCheck
VC_PARAM=9.5
ACTION=INSTALL
ROLLBACKABLE=NO
#==================== Common Main Pages: Install Mode
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS"
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#==================== Common Main Pages: Deploy Mode
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#==================== Common Config pages: Install Mode
[InstallTypePage]
UI_CREATOR=InstallTypePage
[Snap_InstallModePage]
UI_CREATOR=InstallModePage
UI_SOURCE=Setup\ContentServiceUI.dll
#==================== Common Config Pages: Deploy Mode
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
#==================== Common Main Pages: Maintenance Mode
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
1 REPLY 1
Albert_Rius
Install framework(setup.exe) doesn't have a Passive Progress window option. It's either fully silent or Progress bar with Cancel button.
If you really want to make the installation silent with passive progress bar, please use MSIEXEC command (the GPO method documentation should give the relevant mst files). which gives you full control.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
Administrator Productivity
