Installation & Licensing
Product Support
hashim.mundol
Message 11 of 20 (1,108 Views)
Re: AutoCad LT 2013 GPO install issue gpo.mst
09-27-2012 01:29 AM in reply to: martin.franc
hi Martin
Thanks for testing, it. I have re-produced the issue in the lab. and found a work around.
Please use the attached mst (gpo_for_sp1.mst, attached as zip) file instead  of gpo.mst against acadlt.msi
For other msi files (AcadLTLP.msi,AcadLTPS.msi) pelase use the original gpo.mst file.
Please let me know if this helps in deploying AutoCAD LT 2013 Sp1.1
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
martin.franc
Message 12 of 20 (1,103 Views)
09-27-2012 01:58 AM in reply to: hashim.mundol
Thanks, maybe I'll try it later today.
It is also applicable to the x86 version of ACLT2013 (SP1.1)? It has the same problem.
Product Support
hashim.mundol
Message 13 of 20 (1,097 Views)
09-27-2012 03:01 AM in reply to: martin.franc
Yes it should work on 32 and 64 bit.
Hashim Mundol
martin.franc
Message 14 of 20 (1,093 Views)
09-27-2012 03:54 AM in reply to: hashim.mundol
Meanwhile... I found same issue in AutoCad 2013 and SP1.1...
martin.franc
Message 15 of 20 (1,084 Views)
09-27-2012 05:33 AM in reply to: hashim.mundol
I tested it on virtual W7Px64 and it appears that it work (gpo_for_sp1.mst for LT2013). Good job :smileyhappy:. Thank You.
Product Support
hashim.mundol
Message 16 of 20 (1,082 Views)
09-27-2012 05:35 AM in reply to: hashim.mundol
thanks for testing,
same file should work for AutoCAD 2013  SP1.1 too, I haven't tested yet..
Hashim Mundol
martin.franc
Message 17 of 20 (1,080 Views)
09-27-2012 05:38 AM in reply to: hashim.mundol
Really? Give me 30 minutes.... :smileyhappy:
martin.franc
Message 18 of 20 (1,073 Views)
09-27-2012 06:22 AM in reply to: martin.franc
Thanks, works fine with ac&aclt2013. :smileyhappy:
Product Support
hashim.mundol
Message 19 of 20 (1,069 Views)
09-27-2012 06:51 AM in reply to: martin.franc
Thanks for confirming.
Hashim Mundol
Valued Contributor
mbhame
Message 20 of 20 (957 Views)
11-07-2012 12:51 PM in reply to: hashim.mundol
Good Lord, Thank You Hashim!!!
This file works for AutoCAD MEP 2013 w/SP1 embedded as well.
FTR Autodesk Technical Support (1-2 months ago) told me this was because my adminimage share path was excessively-long (even though it wasn't for the prior 5 years of builds).
