Installation & Licensing
Product Support
52 Kudos
Post 11 of 20
Re: AutoCad LT 2013 GPO install issue gpo.mst
09-27-2012 01:29 AM in reply to: martin.franc
hi Martin
Thanks for testing, it. I have re-produced the issue in the lab. and found a work around.
Please use the attached mst (gpo_for_sp1.mst, attached as zip) file instead  of gpo.mst against acadlt.msi
For other msi files (AcadLTLP.msi,AcadLTPS.msi) pelase use the original gpo.mst file.
Please let me know if this helps in deploying AutoCAD LT 2013 Sp1.1
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
0 Kudos
Post 12 of 20
09-27-2012 01:58 AM in reply to: hashim.mundol
Thanks, maybe I'll try it later today.
It is also applicable to the x86 version of ACLT2013 (SP1.1)? It has the same problem.
Product Support
52 Kudos
Post 13 of 20
09-27-2012 03:01 AM in reply to: martin.franc
Yes it should work on 32 and 64 bit.
Hashim Mundol
0 Kudos
Post 14 of 20
09-27-2012 03:54 AM in reply to: hashim.mundol
Meanwhile... I found same issue in AutoCad 2013 and SP1.1...
0 Kudos
Post 15 of 20
09-27-2012 05:33 AM in reply to: hashim.mundol
I tested it on virtual W7Px64 and it appears that it work (gpo_for_sp1.mst for LT2013). Good job :smileyhappy:. Thank You.
Product Support
52 Kudos
Post 16 of 20
09-27-2012 05:35 AM in reply to: hashim.mundol
thanks for testing,
same file should work for AutoCAD 2013  SP1.1 too, I haven't tested yet..
Hashim Mundol
0 Kudos
Post 17 of 20
09-27-2012 05:38 AM in reply to: hashim.mundol
Really? Give me 30 minutes.... :smileyhappy:
0 Kudos
Post 18 of 20
09-27-2012 06:22 AM in reply to: martin.franc
Thanks, works fine with ac&aclt2013. :smileyhappy:
Product Support
52 Kudos
Post 19 of 20
09-27-2012 06:51 AM in reply to: martin.franc
Thanks for confirming.
Hashim Mundol
Valued Contributor
2 Kudos
Post 20 of 20
11-07-2012 12:51 PM in reply to: hashim.mundol
Good Lord, Thank You Hashim!!!
This file works for AutoCAD MEP 2013 w/SP1 embedded as well.
FTR Autodesk Technical Support (1-2 months ago) told me this was because my adminimage share path was excessively-long (even though it wasn't for the prior 5 years of builds).
