Installation & Licensing
Autocad LT 2012 Windows 7 Pro 64 Bit install failing
0 REPLIES 0
Message 1 of 1
thomas
1206 Views, 0 Replies
Please help. I switched OS from Windows 7 Pro 32 bit to W7 Pro 64 bit.  Autodesk sent new download file AutoCAD_LT_2012_English_Japanese_Win_64bit.   I was having issues with the installation of Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603.   I removed other verstions of C++ both 2008 and 2010 and tried install again and I now seem to be having another issue.  I tried the install twice and still the same issue see below.  Please help.
TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:06:36    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:07:04    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:14:07:33    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:14:07:37    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:14:11:25    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:14:11:37    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:14:11:37    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_6
4bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\TRANDR~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/11:14:11:43    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Succeeded
2012/10/11:14:11:43    TRAndrews    TRANDREWSOFFICE    Installing Autodesk® Design Review:  TRANSFORMS="C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:12:29    TRAndrews    TRANDREWSOFFICE    Install    Autodesk® Design Review    Succeeded
2012/10/11:14:12:29    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:13:03    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:14:13:03    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:13:35    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:14:13:35    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:14:07    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:14:07    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:14:16    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:14:14:17    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI2DF2.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:19:42    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:14:19:47    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:14:20:00    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:20:16    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:14:20:16    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk® Design Review    Succeeded
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    Rollback    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1619
2012/10/11:14:20:22    TRAndrews    TRANDREWSOFFICE    PageOpen    InstallCompleteDialog
2012/10/11:14:22:25    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:14:39:07    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:07    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:40:08    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:14:39:08    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:14:39:08    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:14:40:10    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:14:40:39    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:14:40:53    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:14:41:09    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:14:41:11    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:14:41:11    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/10/11:14:41:41    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2012/10/11:14:41:41    TRAndrews    TRANDREWSOFFICE    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/10/11:14:41:50    TRAndrews    TRANDREWSOFFICE    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Succeeded
2012/10/11:14:41:50    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:14:42:32    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:14:42:32    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:43:01    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:14:43:01    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:43:52    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:14:43:52    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:14:44:12    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:14:44:13    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI3F9E.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:00:54    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:15:00:58    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:15:01:11    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2012/10/11:15:01:25    TRAndrews    TRANDREWSOFFICE    PageOpen    InstallCompleteDialog
2012/10/11:15:09:09    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:15:09:47    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:47    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:15:09:55    TRAndrews    TRANDREWSOFFICE    === Setup ended ===
2012/10/11:15:09:50    TRAndrews    TRANDREWSOFFICE    === Setup started on TRANDREWSOFFICE by TRAndrews ===
2012/10/11:15:09:50    TRAndrews    TRANDREWSOFFICE    Launch
2012/10/11:15:09:55    TRAndrews    TRANDREWSOFFICE    PageOpen    LaunchDialog
2012/10/11:15:10:26    TRAndrews    TRANDREWSOFFICE    PageOpen    LicenseDialog
2012/10/11:15:10:29    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductInfoDialog
2012/10/11:15:10:53    TRAndrews    TRANDREWSOFFICE    PageOpen    ProductSelectionDialog2
2012/10/11:15:10:54    TRAndrews    TRANDREWSOFFICE    PageOpen    FullProgressDialog
2012/10/11:15:10:54    TRAndrews    TRANDREWSOFFICE    Installing DirectX Runtime: C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/10/11:15:11:14    TRAndrews    TRANDREWSOFFICE    Install    DirectX Runtime    Succeeded
2012/10/11:15:11:14    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:11:29    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012    Succeeded
2012/10/11:15:11:29    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:11:56    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:11:56    TRAndrews    TRANDREWSOFFICE    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:12:19    TRAndrews    TRANDREWSOFFICE    Install    Autodesk Content Service    Succeeded
2012/10/11:15:12:21    TRAndrews    TRANDREWSOFFICE    Installing AutoCAD LT® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\x64\en-us\acadlt\acadlt.mst;C:\Users\TRANDR~1\AppData\Local\Temp\_AI5669.tmp\x64\acadlt\acadlt-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2012_English_Japanese_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/11:15:14:11    TRAndrews    TRANDREWSOFFICE    Install    AutoCAD LT® 2012    Failed    Installation aborted, Result=1603
2012/10/11:15:14:14    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Content Service    Succeeded
2012/10/11:15:14:27    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2012/10/11:15:14:41    TRAndrews    TRANDREWSOFFICE    Rollback    Autodesk Material Library 2012    Succeeded
2012/10/11:15:14:41    TRAndrews    TRANDREWSOFFICE    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
0 REPLIES 0
Administrator Productivity
