Installation & Licensing
AutoCAD LT 2012 installation on Desktop and Laptop for single user user
1 REPLY 1
technaut
836 Views, 1 Reply
I understand that AutoCAD LT 2012 can be installed on a desktop and laptop if they are for the sole use of a individual user and nobody else.
The documentation located so far refers to installing on both machines and then exporting/importing the licenses backward and forwards between the computers as required with the occassional issue.
I would like to avoid this scenario and assume that if nobody else uses the computers it would be acceptable to install on both machines? If so, what would I need to do to avoid the inconvenience of exporting/importing licenses each time?
I hope to hear from you very soon
1 REPLY 1
TravisNave
in reply to: technaut
Activate your desktop.  Activate your laptop.  Done.
The EULA explains this in detail.  You can do so without issue.  Good luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
