Installation & Licensing
AutoCAD LT 2012 - installation error
9 REPLIES 9
Message 1 of 10
1586 Views, 9 Replies
Hello!
I get the attached error when installing autocad LT 2012. (just after running setup.exe)
(in norwegain it says: "The system cannot open the device or file specified..")
I'm using the original DVD and I have tried this on several PC's but get the same error.
The strange thing is that I installed from this dvd a year ago, and it worked..
any help is appreciated!
9 REPLIES 9
Message 2 of 10
aaronhai
Hi eirikh,
Welcome to Autodesk Discussion Groups.
Please see if it is due to the issues described in this Autodesk blogpost and Forum.
Thank you.
Aaron Hai
Message 3 of 10
in reply to: aaronhai
sorry for late reply to this. No, it doesnt work. Drive is not encrypted. Different media tried to no use. Will check if ordering USB media helps.
Message 4 of 10
Download media tried. I get the same error!
Message 5 of 10
celine.manca
Hi Erik,
Did you already order the media of your product or do you need some help ?
Celine Manca
Message 6 of 10
in reply to: celine.manca
Ordered new media (DVD) and downloaded media as well. Both give me the error described above.
(tried it on several domain Windows7 x64 pc's)
Message 7 of 10
hashim.mundol
Please try to install the software in diagnostics mode as described here.
http://usa.autodesk.com/getdoc/id=TS75218
If it fails, Please try to run this utility from Microsoft to clean the windows installer.
http://support.microsoft.com/kb/2438651
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 8 of 10
in reply to: hashim.mundol
Running this in safe mode was no use, as it needs the windows installer service, which isnt avaliable in safe mode..or so it says.
This one found no errors..and therefore did nothing.
Message 9 of 10
I found the solution - Ran the install in safe mode as admin, and ran this tool to get the Windows Installer service going: http://www.technibble.com/safemsi-exe-start-windows-installer-service-in-safe-mode/
Message 10 of 10
amigos un gran favor miren cuando instalo autocad Civil 3D 2013, justo casi al final de la instalacion despues deinstalar languaje pack  me sale un error que dice "placeholder" que pueddo ahcer porq me sale este error y como puedo subsanarlo estaria muy agradecido si me responden lo mas nates posible gracias
Administrator Productivity
