Dear all,
i try to install my autocad lt 2012 after i key in the serial number and product key i cannot click the install button its freeze im using windows 7. please advise thanks.
ADEEB
Try this Forum where you are likely to get more feedback:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Include any information generated by the freeze.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
You can also try this source for help, the Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=9240817
There should be a green check box next to the serial AND the product key if both are valid. Only then can you continue to configure your product and the install button will activate.
