Installation & Licensing
autocad lt 2012 install button freeze
3 REPLIES 3
adeeb
276 Views, 3 Replies
Dear all,
i try to install my autocad lt 2012 after i key in the serial number and product key i cannot click the install button its freeze im using windows 7. please advise thanks.
ADEEB
3 REPLIES 3
Charles_Shade
in reply to: adeeb
Try this Forum where you are likely to get more feedback:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Include any information generated by the freeze.
pendean
in reply to: adeeb
You can also try this source for help, the Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=9240817
TravisNave
in reply to: adeeb
There should be a green check box next to the serial AND the product key if both are valid.  Only then can you continue to configure your product and the install button will activate.
Autodesk Forums:
Administrator Productivity
