I have a laptop that will not let AutoCAD LT run. When you click on the icon, the splash screen appears, then it closes asking if it can send an error report to autodesk. No error code or message comes up. I have done a clean uninstall, uninstalled all the .net frameworks then installed just 3.5 sp1 with no luck. Any help you can give will be appreciated.
Have you already checked that the disk is not full or corrupted? How much RAM does the laptop have? What operating system and service pack are you using? Is DirectX 9.0c installed properly? Have you tried to reinstall it? What does the Windows event log show?
The disk is not full, and the disk does not seem to be corrupt
It has 2 G ram.
It has directx 9c.
I have completed a clean uninstall and reinstall along with reinstalling the vb and c++ runtimes.
I am runing xp sp2 on machine.
Thank you again for your help.
