Installation & Licensing
Member
zdanielu
Message 1 of 8 (5,444 Views)
AutoCAD LT 2011 - Silent Install
5444 Views, 7 Replies
10-11-2010 01:56 AM
Does autocad supports silent install with no user interaction?
I want to install the app in Deutch language, to include Design Review 2011, all features + the Service Pack( product update 1.1)
How can i do that?
Thanks.
Product Support
hashim.mundol
Message 2 of 8 (5,431 Views)
Re: AutoCAD LT 2011 - Silent Install
10-11-2010 02:30 AM in reply to: zdanielu
Yes creating deployment image would be the best option; here you include Update 1.1( please use append option while creating image to add the update)
http://docs.autodesk.com/ACDLT/2011/ENU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-5174.ht...
Or you could script it as well; which would need the pre-requisites installed seperately.
http://docs.autodesk.com/ACDLT/2011/ENU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.ht...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Member
zdanielu
Message 3 of 8 (5,388 Views)
10-13-2010 01:09 AM in reply to: hashim.mundol
Thank you for the script, i still need to manage to install the app in Deutch, is ther a language parameter? or how can i change the language.
Product Support
hashim.mundol
Message 4 of 8 (5,385 Views)
10-13-2010 01:22 AM in reply to: zdanielu
The Languages are mentioned in the script
 de-DE = Deutchland German
If you want the German version of the documents you can get it here (replacing ENU with DEU in the URL; this is applicable most Autodesk 2011 help files)
http://docs.autodesk.com/ACDLT/2011/DEU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.ht...
Hashim Mundol
Member
zdanielu
Message 5 of 8 (5,320 Views)
10-20-2010 03:20 AM in reply to: hashim.mundol
many thanks,
i have installed the application using this command, this is with no UI
strInstCommandLine = """" & strCurrentDir & "\setup.exe" & """" & " /w /t /qb" & " " & "/Language" & " " & "de-DE" & " " & "/c ACADLT:" & " " & "INSTALLDIR=" & """C:\Program Files\Autodesk\AutoCAD LT 2011 de-DE\""" & " " & "ACADFIRSTNAME=" & """PC""" & " " & "ACADLASTNAME=" & """User""" & " " & "ACADORGANIZATION=" & """NAME""" and the parameters for the license
Using this command allows users to click cancel installation, and "qb!" =  no cancel button is not working, is there another solution to hide the cancel button?
Product Support
hashim.mundol
Message 6 of 8 (5,307 Views)
10-20-2010 04:07 AM in reply to: zdanielu
 /q or /qn should be completely silent.
if wish to see some progress bar you could try /passive along with /qb (i haven't tested these)
Hashim Mundol
Member
shruthi_sreenivasan
Message 7 of 8 (2,584 Views)
05-23-2012 02:40 AM in reply to: zdanielu
what parameter can i pass to  the setup to remove the desktop shortcut permanently?
Product Support
hashim.mundol
Message 8 of 8 (2,575 Views)
05-23-2012 12:03 PM in reply to: zdanielu
It would be best to use Deployment image to control these behaviour.
if you really want MSI parameters. (I havent tested these)
Please try
ADSK_DESKTOPSHORTCUT_1=0
and
ADSK_DESKTOPSHORTCUT_2=0
Hashim Mundol
