Installation & Licensing
Active Member
0 Kudos
Post 1 of 20
AutoCAD LT 2011 license transfer and re-activation issue
2828 Views, 19 Replies
04-23-2012 02:52 AM
Hi all,
I got a bunch of multi-seat stand-alone AutoCAD LT licenses that have upgraded over the years from LT 2005, 2008, 2011 and finally 2012 (that is in progess during these last weeks).
I am having some troubles to perform the license transfer from a workstation that needs to be decommissioned to a just-commissioned one on which AutoCAD LT 2012 is installed and will need the upgrade serial number as soon the agreement renewal process is done.
Looking in About >> Product Information within the software the multi-seat stand-alone license serial number appears in “Blocked” status and to successfully transfer it to another machine it says that it needs first to be re-activated.
Unfortunately from both the license transfer utility and the Autodesk website I got the message the it is not a valid serial number!
I also checked on another still-in-place workstation and it is the same so now I am guessing if it might be possible that the license agreement renewal process is currently blocking the old serial number.
How do I would sort this out and and what is the exact procedure to follow up in order to transfer and upgrade the license?
I need your precious help support service.
Thanks in advance,
Marco
Customer Service
13 Kudos
Post 2 of 20
Re: AutoCAD LT 2011 license transfer and re-activation issue
04-23-2012 03:15 AM in reply to: mmengoni
Hi Marco!
If the transfer of the license doesn't work, we can provide you a new activation code.
Could you please send me your serial number by private message (envelope next to your name) ?
Thank you!
Celine Manca
Active Member
0 Kudos
Post 3 of 20
04-23-2012 03:33 AM in reply to: celine.manca
Hi Celine,
Serial number just sent in PM.
Marco
Active Member
0 Kudos
Post 4 of 20
04-23-2012 07:02 AM in reply to: mmengoni
Hi Celine,
The activation code you gave me worked fine as you can see below (sorry it is in Italian, I put * instead of my license data):
AutoCAD LT 2011 Informazioni sulla registrazione
Fare clic sul pulsante Stampa del browser per stampare questa pagina. Il file delle informazioni sulla registrazione è stato salvato in  C:\Documents and Settings\All Users\Dati applicazioni\Autodesk\Adlm\ACDLT2011it_ITRegInfo.h​tml
Informazioni sul software Prodotto: AutoCAD LT 2011
Numero di serie/ID gruppo: ***-********
Chiave di prodotto: *****
Codice di richiesta: **** **** **** ****
Informazioni sulla società Nome:
Indirizzo 1:
Città:
CAP:  Paese:
Informazioni di contatto Nome:
Telefono:
Informazioni su Autodesk Internet: http://www.autodesk.com Registrazione via Internet: https://register.autodesk.com
E-mail: authcodes@autodesk.com Fax: 800-225-6490
Telefono: 800-551-1490 or 415-507-4690
2012-04-23T15:19+01:00               Versione 1.3.34.0
Anyway the OLTU is still unable to export the license and transfer it on the Autodesk servers and keeps saying that this is not a valid license:
Numero di serie:  ***-********
Richiesta di esportazione non riuscita
Il numero di serie immesso non è valido. Riprovare. (Errore 1)
Fare clic sul collegamento "Riprovare" per inviare nuovamente la richiesta.
Riprovare
Riferimento errore:1
Finally here is the Product information extract from AutoCAD LT 2011 (still usable as before):
[Proprietà delle informazioni sul prodotto]
lunedì 23 aprile 2012 15.23.46
Nome licenza: AutoCAD LT 2011
Nome host computer: ********
Numero di serie del prodotto: ***-********
Tipo licenza: Singolo utente - Bloccata
Data di scadenza licenza: Nessuna
Modalità licenza: Permanente
Tipo di utilizzo della licenza: Commerciale
ID licenza: ACDLT_F_S
Do you have any special advice to sort this out?
Marco
Active Member
0 Kudos
Post 5 of 20
04-24-2012 05:51 AM in reply to: mmengoni
For completeness here is a brief summary of the reply received in PM from celine.manca about hints provided by the Registration & Activation team :
Once a serial number is upgraded, the system recognizes only the latest version even if it was not yet activated and in this case it is necessary to process a manual activation.
- How can I transfer the license away from the actual workstation?
Only licenses with Registered status and/or under active Subscription contract can be transferred through OLT.
- Is there any off-line tool or alternative method to do a backup of the license?
Unfortunately there are no off-line tools that allow to create an activation backup. The only real alternative is manual activation. Customer can forward the request through Autodesk webform and eventually call Reg&Act department at +41 327 23 95 95 once obtained the Case No. in order to prioritize the case.
In my case I can proceed with the re-imaging of the workstation and finally I will ask you in PM a new manual activation code later.
Thanks for your efforts,
Marco
Active Member
0 Kudos
Post 6 of 20
04-27-2012 04:07 AM in reply to: mmengoni
Hi Céline,
I re-imaged my workstation and have just sent you by PM a new manual activation code request.
Waiting yours.
Marco
Active Member
0 Kudos
Post 7 of 20
05-28-2013 12:50 AM in reply to: mmengoni
Hi Céline,
I sent you a msg in pm but didn't got any reply.. :smileysad:
Is there anybody else from Autodesk support team that may help?
I re-imaged a CAD workstation and need URGENTLY new activation code request!!
Looking forward for help.
Marco
179 Kudos
Post 8 of 20
05-28-2013 01:32 AM in reply to: mmengoni
Hi Marco,
Please, send me your serial number and request code via Private Message and I will take care of this for you.
Camilo Lemos
New Member
0 Kudos
Post 9 of 20
08-14-2013 07:11 AM in reply to: mmengoni
I also get the message licence not valid. (Export Failed)
I used the licence transfer utility.
I would like to transfer the licence to another client.
Could you help me.
Thank you
Active Member
0 Kudos
Post 10 of 20
08-14-2013 07:31 AM in reply to: mmengoni
You need to PM Camilo Lemos or Céline Manca.
They for sure will help you. with your license issue.
Marco
