Installation & Licensing
AutoCAD LT 2011 - Install ok, can't start
4 REPLIES 4
546 Views, 4 Replies
I've just transferred AutoCAD LT from one pc to another (both Win7 Pro 64). The installation went well, the license got transferred with the provided tool.
Now, AutoCAD doesn't start on the new pc. I'm only getting the error msg (see attached) stating that
either AutoCAD didn't get installed correctly, or the user doesn't have the rights to start it.
As I've said, the installation went smoothly. The user has admin rights on this machine. And yes, I've already tried to uninstall everything (including registry clean-up, etc) and re-install. Same result.
My user is getting impatient, and I need to solve that asap.
Thanks in advance for any hint...
Greets
--Pierre
4 REPLIES 4
aaronhai
Hi pmoret,
Try re-activating AutoCAD LT. If you only have 1 product installed in your machine, please delete the adsk*.data file to force re-activation. To delete the licensing info, backup and remove these files:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.?backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
Then, contact Autodesk Registration & Activation Team for manual activation.
*Select Registration or Activation of a Product, under What type of License Assistance do you need drop-down box, fill in your details and type your query under Anything else you want to tell us box.
OR call:
US:1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
Thank you.
Aaron Hai
Hi Aaron,
Thanks for your help. I'll try that tomorrow, and will report here.
Greets
--Pierre
in reply to: aaronhai
Aaron,
I've tried your suggestion, but it didn't change anything. AutoCAD still doesn't start.
 Smiley Frustrated
--Pierre
BTW, I've also tried to right-click on the icon and to run it with admin rights. Still no luck.
Administrator Productivity
