Installation & Licensing
AutoCAD LT 2011 - Error reference: 41
4 REPLIES 4
guest_infom
7864 Views, 4 Replies
Licence Import Confirmation came out Error reference: 41 when I try to import license from Autodesk.
Previously install to another notebook but something happen then need to format, so everything is uninstalled!
Never do any import/export license.
Now not using another notebook and install AutoCAD LT 2011 using same license.
But to activate, can I using previous activate code? OR can I activate again?
What happen to my license then?
Anyone can help and explain?
Really appreciate & thanks
Tags (1)
4 REPLIES 4
emily.xu
in reply to: guest_infom
You need export your standalone license to Autodesk server before reformat your machine, and then import.
If you have some problem during the process and license lost, it would be better to reactive your program then.You can connect internet and active automatically or contact your reseller or our businees center to help you.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
guest_infom
in reply to: emily.xu
Thanks Ms Emily Xu,
Meaning I need to reactive my program. To reactive, just click the button 'Active' correct? Meaning I will get activation code one more time?
Thanks in advance.
emily.xu
Yes, if you connect the internet, just click active, then you will finish the process automatically.and you can reactive your product in the case of system crash, reformat your machine or lost your license by accident.
Emily Xu
Product Support
In installed Composite Design 2014 according to instructions and it won't start due to a licensing error.  It was installed on Windows 8.1
Administrator Productivity
